Engines won't start!!! Batteries?
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: Engines won't start!!! Batteries?
Genset should have a starting battery as that is all it does..start the genset.
The other 2 are both house and starting batteries. They both should be deep cycle. They will start your engines just fine and will better hold up to the needs of the house.
I had a Carver 3807 for 7 years with twin 7.4's and my deep cells never caused us any problems.
Some may suggest the dual purpose deep cell/ starting battery. I've read lots of threads over the years saying that is not a good way to go.
Your nav lights are of course 12 volts, so if your 12v is dead no nav lights. If your other 12v stuff works on the bridge, dash lights depth finder etc. It is an isolated issue. I would check each light individually. Id doesn't take much for these to stop working. Pull a bulb, test it for continuity, and test for 12v with the nav light switch on. If both are ok, take some light sandpaper and clean the fixture contacts and the bulb contacts.
If you don't have 12v check the Nav light breaker. Mine is on the bridge under the front seat, not sure where they are on a Mariner.
- jcoll
- Has thanked: 18 times
- Been thanked: 18 times
buster53 wrote:Source of the post My suggestion on batteries...others may not agree,
My experience with batteries has been the same. The deep cycles start the engines without any noticeable down side. Longevity has been good and the deep cycle is what I want when anchoring overnight.
- mjk1040
- Been thanked: 248 times
- RickieT
- Vessel Info: Carver 350 Mariner 1997
- Been thanked: 3 times
- Contact:
Any thoughts?
Got a guy helping me and my next step is to bring the 2 batteries in to be load tested. They can read 100% charged and have no current according to him. So frustrating...want to her out to see if port engine is still overheating and can't even start the damn boat to do so!
- Has thanked: 603 times
When you turn the key to start do you hear the start alarm, at the engines do you hear anything at all ?
- RickieT
- Contact:
- RickieT
- Contact:
I checked the handles are in neutral and when try to start either engine the volt meter dives right down.
