thermostat for marineair 3 knob control
sep4086
Vessel Info: 1990 3867 SANTEGO
2003 PRO LINE 26 WALK
Has thanked: 2 times
Postby sep4086 » January 11th, 2018, 5:46 pm
I have a 1990 santego 3867 and I need a new thermostat that mounts on the 3 knob control. Anyone know where I can purchase one and what it will cost?
SplashyLady
Has thanked: 20 times
Been thanked: 88 times
Re: thermostat for marineair 3 knob control
Postby SplashyLady » January 12th, 2018, 10:07 am
You may find you are better off to just upgrade your controls for $175: http://www.marinaire.com/Marine-Air-Con ... ck1-an.htm
Captain John
Lake Norman, NC
Carver 3227 - "Splashy Lady"
Postby Viper » January 12th, 2018, 7:16 pm
I agree. The electronic conversion will give you more functionality plus a digital readout which is always handy so you can set a pretty accurate temperature. The other option is to keep an eye on eBay for the original controller.
Have you tested the t-stat and confirmed that it has indeed failed?
sep4086
Postby sep4086 » January 14th, 2018, 10:03 am
I looked at the upgrade unit and I think I will keep looking for the thermostat as the easy fix.
Postby Viper » January 14th, 2018, 10:40 am
Try these guys, I think there may be one part way down the page:
https://www.tampabaymarineair.com/2794.html
RaRa
Vessel Info: 1990 Carver 32 Montego
Has thanked: 18 times
Postby RaRa » March 12th, 2018, 10:52 am
I had my t-stat fail. I was told that the T-stat was $100 and easy enough for me to install without another service call Apparently the cold winter causes it to stay in heat only. Cabin was about 90 degrees. I am going to look for the digital replacement option as the tech told me is a better way to go until the 15 year old compressor finally dies. It is a B-O-A-T after all!
1989 Montego 3257 @ Galveston Yacht Basin
Postby tomschauer » March 12th, 2018, 5:58 pm
https://www.facebook.com/baltimoremarinesalvageinc
A good source for older boat parts.
RaRa
Postby RaRa » March 14th, 2018, 11:11 pm
And of course the compressor really did die! Now I need to think about a new unit.
RaRa
Postby RaRa » March 14th, 2018, 11:23 pm
To add on to the above, is this really as simple a job as it seems? Since unit is recharged from factory, hooking up seawater in and out and running control lines in a suprisingingly accessible chase will have us cool and warm again. Any likes or dislikes as to brand of units? Prices seem to vary wildly.
Postby tomschauer » March 14th, 2018, 11:46 pm
If you want a simple change out, look for a unit with the same dimensions, capacity and connections as your existing unit.
I have used mermaid and marine airr, both work well. The marine airr has more complex controls. The mermaid will work with any thermostat.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 27 guests
