Installing New Depth Transducer - Mariner 360
Barnaclebill
Vessel Info: Lindy Star
2004 Carver 360 Mariner
Volvo 5.7 Liter GXI Gas Engines
Postby Barnaclebill » March 13th, 2018, 3:54 pm
Has anyone Installed a new Depth Transducer for a Mariner 360? I am trying to figure out how to fish the cable from the bilge to the bridge. I am replacing a old analog unit with a shoot thru the hull digital one.
Barnacle Bill
Lindy Star
Twin Volvo 5.7L GXII-F
Southport, NC
Been thanked: 248 times
Re: Installing New Depth Transducer - Mariner 360
Postby mjk1040 » March 13th, 2018, 5:30 pm
Well good luck with this! I would start by looking around the helm to see where ur shift and throttle cables come up, most likely ur going to have to follow them back to the bilge.
Postby bud37 » March 13th, 2018, 6:44 pm
Barnaclebill wrote:Source of the post Has anyone Installed a new Depth Transducer for a Mariner 360? I am trying to figure out how to fish the cable from the bilge to the bridge. I am replacing a old analog unit with a shoot thru the hull digital one.
Sorry haven't put one like that in, but I have the 01 version of your boat.....there appears to be two ways from the engine room...thru the bilge centre , there is a wire run and the other would be up the stbd side.....each one of those will go up to the bridge......not sure if yours is the new layout ??...if the old design, go up behind the entertainment centre stbd side.....good luck man........ :beergood:
Been thanked: 490 times
Postby waybomb » March 13th, 2018, 7:08 pm
When you do pull, pull an extra chord with your wires to make it easier next time you need to run something
SanJuanDreamer
Vessel Info: Still Searching
Been thanked: 21 times
Postby SanJuanDreamer » March 13th, 2018, 8:54 pm
I have a 98 Mariner 350. I ran the cable from the far starboard side up to the bottom of the arch.
From the arch, there is a tube heading forward, then under the walkway, over the top of the entertainment and then up through a hole in the bridge floor. yours probably different but the tube located at the bottom of the arch was the key for me.
Been thanked: 470 times
Postby RGrew176 » March 13th, 2018, 10:54 pm
If the wiring is still there for the old unit you could cut the old wire at the transducer and tape the new wire to the old and with someone down below and someone up topside feed and pull the new wire up to the bridge.
I helped a guy do just that a few years ago. You will need to have 2 people to make it work.
Barnaclebill
Postby Barnaclebill » March 22nd, 2018, 4:07 pm
Thanks to everybody for the ideas. I will post when I do the job.
Barnacle Bill
Lindy Star
Southport, NC
Users browsing this forum: No registered users and 5 guests
