Using aft reserve tank?
Re: Using aft reserve tank?
Postby tomschauer » March 17th, 2018, 12:31 am
I don't know if your 3807 has one or two aft tanks. I have a single aft tank, I believe it is 120 or 125 gallons. I have dedicated fuel lines to the selector switch and I can run both engines on the aft tank. If I am going on a cruise of any distance, I use it first, then switch to the saddle tanks.
I don't use the aft tank often, but try to run two fills a season through it.
Postby Viper » March 17th, 2018, 6:27 am
Unless it was an option and put under the bed, I don't think aft tanks applied in 3807s. I've never seen a 3807 with a tank back there but there is room for one. Pretty sure all the aft/aux tanks utilize dedicated lines for each engine so you can run both engines at the same time.
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Postby buster53 » March 17th, 2018, 9:51 am
Sorry for the confusion guys. At one point, I did have a 3807. I'm now under contract to buy a 356 which does have 3 tanks.
I've changed my profile.
Postby km1125 » March 17th, 2018, 10:20 am
You should be able to, as long as the vent does not have any restrictions (bugs, nests, kinks, etc)
Been thanked: 248 times
Postby mjk1040 » March 17th, 2018, 3:15 pm
What year 356? Our neighbors 2001 356 tank just let go. Rusted thru from the inside. The aft tank is a V bottom tank and all the moister collects at the bottom of the V. Plus I understand that Carver acquired some substandard tanks at one time.
Postby bud37 » March 17th, 2018, 3:45 pm
mjk1040 wrote:Source of the post What year 356? Our neighbors 2011 356 tank just let go. Rusted thru from the inside. The aft tank is a V bottom tank and all the moister collects at the bottom of the V. Plus I understand that Carver acquired some substandard tanks at one time.
Good grief...the tank lets go in 7 years....Maybe the takeaway from that is to assume the tank is bad and go from there in these models, not something I would expect.....maybe err on the side of safety, unless in your friends boat he had some electrical issues that were hiding in there to create the corrosion problem.....
buster53
Postby buster53 » March 17th, 2018, 8:52 pm
We're looking at a 2001.
I think mjk1040 meant to say 2001. 356's weren't made after either 03 or 04.
Postby bud37 » March 17th, 2018, 9:12 pm
Aha....bit of a difference there.....my misunderstanding. :blush:
Nevertheless buster53, be careful....good luck going forward.
Postby mjk1040 » March 18th, 2018, 4:43 am
Yea its a 2001! Got to proof read before I submit!
PhilH
Vessel Info: Carver Californian 45 M/Y, 1990 Cat 3208 diesels
Has thanked: 5 times
Been thanked: 3 times
Postby PhilH » April 23rd, 2018, 1:50 am
Hi everyone. I have a 1990 Californian 45 with 3 Diesel tanks. Two 100 gal saddle tanks in the engine room and a 260 gal tank aft under the bed which has the water tank sitting on top of it. I heard somewhere these fuel tanks leak because of their low position near the bilge and corrosion problems. Has anyone else heard of this happening? Otherwise will have to pressure test which is kind of a pain since the shops in the area don't seem to specialize in tank pressure testing in place. Viper, have you heard anything about this?
