Epoxy Putty
- SanJuanDreamer
- Has thanked: 1 time
- Been thanked: 21 times
Epoxy Putty
Has anyone used epoxy putty instead of gel coat repair?
- Has thanked: 603 times
Re: Epoxy Putty
Re: Epoxy Putty
- SanJuanDreamer
Re: Epoxy Putty
Its a small void between the rudder base and hull.
Its about the width of a pencil, 5cm deep and 10cm in length.
Not alot, just need a filler.
I was going to use gelcoat with fiber filler, to make it a putty but I was tihnking epoxy would be just as good...and its already a putty.
Re: Epoxy Putty
Re: Epoxy Putty
SanJuanDreamer wrote:Source of the post Its hard to explain, a picture would do here.
Its about the width of a pencil, 5cm deep and 10cm in length....
A picture would help. Are you sure this isn't part of the design? Is the other side the same?
The thing that stands out the most here is an American using the metric system
- SanJuanDreamer
Re: Epoxy Putty
I suppose it should have been 5mm deep and 10mm in length....but...still a pencil is a pencil.
Re: Epoxy Putty
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
Re: Epoxy Putty
He must spend a lot of time up in Canadian waters,
..Aaron
SeaDragon
Users browsing this forum: Google Adsense [Bot] and 26 guests
