Walter V Drive Systems Gearbox Q
- 390Express
- Captain
- Has thanked: 141 times
- Been thanked: 15 times
Upon inspecting the Walter V Drive gearboxes, I noticed that the gear oil was slightly milky. It wasn't a total milkshake, it just had some strands of milky residue on the dipstick. What are the chances that the gearboxes were not properly winterized, and the oil cooler freeze cracked? (the inlet was in the open position, and the hoses are still attached, and fine, with no water or antifreeze in them) We had a rough winter and spring in MI, and it's not uncommon for a small amount of milk to form from condensation.
If a busted oil cooler is a likely issue, how difficult will it be to pull the top plate off, and inspect the same? Does anyone have any pics or advice? The water inlet for the coolant lines was in the open position, no water in the lines, and the lines are in good shape. The motors were properly winterized, and are not freeze cracked, as was the generator. Is SAE 30 the proper lube for the gear boxes? Any recommended brands, or is any quality oil acceptable?
Do these gearboxes have a water pump that draws water, or do they rely on the propulsion of the boat to draw water from the lake? I didn't see any pump on the lines.
- mjk1040
- Been thanked: 248 times
Re: Walter V Drive Systems Gearbox Q
390Express wrote:Source of the post......a 390 Trojan Express (made by Carver, I believe)......
Correct. If my history serves me right, nothing about this model is original to the Trojan design except the name.
390Express wrote:Source of the post.......Upon inspecting the Walter V Drive gearboxes, I noticed that the gear oil was slightly milky. It wasn't a total milkshake, it just had some strands of milky residue on the dipstick. What are the chances that the gearboxes were not properly winterized, and the oil cooler freeze cracked? .... how difficult will it be to pull the top plate off, and inspect the same? .....
Some condensation is not uncommon but if there is any suspicion of frost damage, you should pressure test the raw water side of the drive. You don't want to run it if there's a crack in the cooling side of the housing, it'll eventually fail and leave you stranded somewhere. Not that difficult to pull off the top plate but you should pressure test before you do that.
390Express wrote:Source of the post.....Is SAE 30 the proper lube for the gear boxes?......
YES
390Express wrote:Source of the post...... Do these gearboxes have a water pump that draws water, or do they rely on the propulsion of the boat to draw water from the lake? I didn't see any pump on the lines.
They do not have their own water pump. The isolated Walter drives were plumbed a couple of different ways so it depends on how the OEM set them up; In some applications, the raw water pump on the engine draws water through the drive then on to the engine. This would remove heat from the drive first before the water heads to the engine cooling system. The other way they were plumbed was the water would go through an intake, up through the unit, then straight back down to a separate thru-hull outlet. One scoop would face fore and the other aft. Cooling water would only go through the unit while the vessel was underway in forward or reverse, no pump involved. The motion of the vessel would force water through the unit. Since no heat is generated in neutral, this worked just fine. There would be a separate intake for the engine.
- Lobscouser
- Vessel Info: current 1995 Carver 430 ACMY
previous 1989 Carver 38 Santego
previous 1976 Carver 33 Mariner
and various inland and blue water sailing craft on the Pacific and Galveston Bay
'I will look for future posts and help as much as possible,
Lobscouser
No torque converters applicable here. Are you referring to a torque converter you'd find on an automotive transmission?
- 390Express
- Captain
Viper wrote:Source of the post It would help to know exactly which model Walter drive you have. Do you have the unit that's separate from the engine transmission and is hooked up by a drive shaft with u-joints?
Yup, tried to attach a pic below. We'll see how it goes.
390Express wrote:Source of the postSome condensation is not uncommon but if there is any suspicion of frost damage, you should pressure test the raw water side of the drive. You don't want to run it if there's a crack in the cooling side of the housing, it'll eventually fail and leave you stranded somewhere. Not that difficult to pull off the top plate but you should pressure test before you do that.
What is the best way to pressure test the gearbox with no... pressure? The boat is miles away from water and electricity. I may be able to plug one end and blow into the other, but I'm not sure what extent that will help anything. The hoses are long and large, (no low brow jokes!) and my lungs are only so big... Is the extent of the fresh water cooling system simply the two hoses and the small snake looking cooler at the top, under the 6 bolts (I haven't removed my top cover to access the cooler, I just googled the cooler)? And, if so, is it as simple as removing those 6 bolts to remove the oil cooler, or is it more involved than that? I would like to try to remove the oil cooler and take it back to the shop to pressure test it, as long as it isn't one of those deals that will "never go back together the same again."
390Express wrote:Source of the postThe other way they were plumbed was the water would go through an intake, up through the unit, then straight back down to a separate thru-hull outlet. One scoop would face fore and the other aft. Cooling water would only go through the unit while the vessel was underway in forward or reverse, no pump involved. The motion of the vessel would force water through the unit. Since no heat is generated in neutral, this worked just fine. There would be a separate intake for the engine.
I believe this is how mine are plumbed. I have a separate sea strainer on the line, and a separate inlet/outlet, with shutoff valves. The valves were left open, and the strainers have been drained. The drive is red tagged "ok for shipping." Given that the cooler is the highest point in the system, the cooler isn't all that big, that there are few restrictions in the cooler setup for water to "stand", the system was left open, and it was hauled 400 miles up I-75 with the system open drawing air, I'm optimistic that even if not winterized, it would have drained naturally, or any water that did freeze would have had an easier place to go, than cracking the oil cooler.
Can anyone tell me what make/model transmission I have based on the pic (Paragon, Borg Warner, Walter, etc.). We've had a ton of old school TRS offshores. I'm familiar with the BW transmission, but this one looks a bit different. After I'm confident that the Walter V Drive gearbox is in good order, I'll be looking into the transmission next.
Eternally grateful for the replies thus far. Thanks fellow forum members!
- 390Express
- Captain
- mjk1040
- Has thanked: 603 times
- 390Express
- Captain
mjk1040 wrote:Source of the post The sea strainer appears to be full of pink antifreeze! If that's the case I'd bet they winterized them. That sure is an animal I haven't seen before!
Ha, I think it's just rusty/crusty with some residue in there. I believe they're dry, but I'll check them next time I'm there. It's finally starting to warm up. I've been spending an hour here and there, freezing my tail off, crammed in the bilge, trying to do as much as possible. Our "spring" has been horrible here in MI.
bud37 wrote:Source of the post Looks like a velvet drive, my guess from the pic angle .......should be an id plate on there by the dipstick ???, maybe painted over......
Ty, it looks smaller than my old BW velvet drive, and a slightly different dipstick configuration, but my old trans was more than a decade older. I'll look for an ID plate. What's the best way to drain the trains fluid completely (or flush)? I'd like to do more than the dipstick extraction if possible. I'm looking to have it as right as possible when it hits the water. I'm hoping to not have to spend $300+ to haul it back out once it hits water.
