Sherwood e35 pump bearing
throwback2
Vessel Info: 1987 Carver 28 Voyager,twin small blocks,1991 Shamrock,350 Chevy now.
and a few other water toys
Has thanked: 8 times
Been thanked: 23 times
Re: Sherwood e35 pump bearing
Postby throwback2 » April 19th, 2018, 6:35 pm
MakinTime wrote:Source of the post Throwback..what did you use for a bracket to secure the pump?
I ordered the brackets when I bought the pumps,can't remember what they look like.I will check the next time I get on the boat and get a picture.
MakinTime
Vessel Info: Carver 3607 MakinTIme
Glastron MX175 MakinTimeToo
Has thanked: 52 times
Been thanked: 31 times
Postby MakinTime » April 19th, 2018, 7:41 pm
Thanks for the input guys I will pull covers off and take a peak at the impellers. I got the starboard side pump on today so and pre made a bracket then take it to work and paint it. I’m glad I did my own brackets, it’s nice to be able to turn the pump for better hose routing.
throwback2
Postby throwback2 » April 20th, 2018, 7:58 pm
Here's a picture of the pump and bracket
MakinTime
Postby MakinTime » April 20th, 2018, 8:11 pm
Awesome thank you for the pic. I made some brackets today and they should work out good I will post pics after install. Thanks much.
MakinTime
Postby MakinTime » April 23rd, 2018, 7:17 pm
Put the new pumps in this weekend got it all pretty much ready to go..ran out of hose clamps to double up on the pump side. Here are pics of my brackets and rubber mounting stud I put into the pump for mounting... worked out very well. Thanks all for your inputs.
Postby bud37 » April 23rd, 2018, 7:35 pm
Nice job...looks like it will work just fine........how was lining up the flange on the pulley ??....
MakinTime
Postby MakinTime » April 23rd, 2018, 7:50 pm
On the pully there was 2 alignment holes that the pump fit into so it worked out well!
throwback2
Postby throwback2 » April 24th, 2018, 12:22 pm
MakinTime wrote:Source of the post Put the new pumps in this weekend got it all pretty much ready to go..ran out of hose clamps to double up on the pump side. Here are pics of my brackets and rubber mounting stud I put into the pump for mounting... worked out very well. Thanks all for your inputs.
Brackets look good,I think you will like those pumps too.
Users browsing this forum: Google [Bot], Rocketman and 37 guests
