Voyager 570 Props
- voy570ager
- Vessel Info: 2004 570
Voyager 570 Props
Just had a sand bar come at me at 25kts and ground my boat. I didn't see it coming. yes ha ha
My props have been worked a lot and I may need new props.. Volvo d-12's
I had 4 blade ZF 29 X 32.2 with a slight cup..I got 2370 rpms and WOT speed was 27.3 kts/31.4 MPH
wondering what props you are using on your boat and what number are you getting.
Re: Voyager 570 Props
I can't help you with performance data but a good prop shop should be able to help you get into the performance curve you're looking for based on your application. You can also contact Carver and discuss your needs with their tech department. At the very least they should be able to provide you with the specs for the original props and how the vessel performed with them.
- voy570ager
Alaska 530 Voyager
- Has thanked: 42 times
- Been thanked: 36 times
Does anyone know what prop works good on these older 530s with the 122 Volvos?
Please forgive me if I'm using this forum wrong, I'm new. Thanks.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Alaska 530 Voyager
- Cooler
That vibration is something you want to figure out. If previous owner hit something hard, with Nibral props, that energy could have transferred to the shaft pretty quick. Did you check for misalignment at engine? Good luck! Cooler
Alaska 530 Voyager
- Has thanked: 603 times
