454xli Repower
- SanJuanDreamer
- Has thanked: 1 time
- Been thanked: 21 times
454xli Repower
She has 1510hrs on both motors and port motor has a serious miss.
Shop says #4 cylinder is not holding compression.
Blue smoke and gas smell is strong.
Oil pressure good on both motors at the lower rpms, but after coming down from plane, oil pressure drops extremely low, like in 5lb area until oil cools, then it’s back to 40lb
Anyone have experienced insight you could offer?
I don’t have time to do it, I’ll be asking a shop to do it…
Re: 454xli Repower
But I believe I would dig in just a bit deeper before you sacrifice a good part of your season and bank account.
Are the crusaders throttle body or multi port injection? If multi port, the gas smell and low oil could be too much fuel in one or more cylinders. If enough over fuel, it would thin your oil, and when the fuel evaporates, wala, oil pressure again. I guess depending on the layout of the intake, this could also happen with a throttle body setup. I would assume then, it would effect four or eight cylinders, not just one or two.
I'm sure Viper will have more insight.
Re: 454xli Repower
What grade of oil do you use? Do you get blue smoke ALL the time or just at startup?
The hours are high for a gasser but I always say it's more about the way the engines were run and whether they were properly maintained that dictates whether the high hours are a problem or not. The problem is you don't know what previous owners did unless they all provided meticulous records.
Re: 454xli Repower
Re: 454xli Repower
- mjk1040
- Been thanked: 248 times
Re: 454xli Repower
- Has thanked: 603 times
Re: 454xli Repower
- SanJuanDreamer
Re: 454xli Repower
When the engines are running at 13rpm or less, the oil is ~40lb and steady.
When she gets up on plane 36rpm, after 10-15 minutes, the pressure will start slowly lowering, usually holding at about 20-25lbs
As soon as she comes off plane, they both register just at 5lbs or slightly above.
As the engine cools, the pressure will increase.
Its a progressive slide over the years.
I've had mechs recommed a top end job, but they haven't seen the oil pressure side of the story.
Meaning, If I spend bucks on a top end, to find the bottom is getting bad...then I made the wrong choice...and I get to pay for it again.
Re: 454xli Repower
I'm assuming you're salt water application and closed cooling?
Re: 454xli Repower
Definitely need more diagnosis on the bad cylinder, but I agree, don't do anything to the top end until you figure out what the bottom end is doing.
