Shower leak 460 Carver
Topic author
boatfamily4
Vessel Info: 2005 Carver 460 Voyager
Postby boatfamily4 » March 18th, 2014, 4:18 pm
I own a 2005 Carver 460 Voyager. The guest head shower is leaking. we have traced it to the hot/cold water exchanger under the sink. Does anyone know where I can purchase a replacement one? (picture attached)
Thank you!
Been thanked: 490 times
Re: Shower leak 460 Carver
Postby waybomb » March 18th, 2014, 7:00 pm
Are you sure it is leaking for the valve (the brass part), or is it leaking from one of the fittings?
Carver should be able to tell you where to get the valve if it is leaking.
If one of the fittings is cracked, a plumbing house can help. They may even be able to help you with the valve.
If it is leaking at a fitting/vale joint, all you may have to do is remove the valve and tighten up the leaking fitting.
