replacing an old ice maker
jeffceo
Topic author - Scurvy Dog
- Vessel Info: 1987 Carver 3807 aft cabin
- Ramsport47
- Has thanked: 72 times
- Been thanked: 59 times
Re: replacing an old ice maker
T-Merc 350 Mag MPI (300hp)
SHEMP
- Vessel Info: 2000 CARVER 456 MY
Full Bridge and aft deck enclosure
Originally purchased in Staten Island
Second owner also purchased in Staten Island in 2012
Now berthed in Toronto Canada
A wonderful and fully appointed luxury yacht. - Location: Toronto Ontario Canada
- Been thanked: 4 times
I replaced the module on my Raritan myself. I found the unit at Sears parts. Its the identical unit , used in household refrigerators. Mine cost me $180 Canadian. Every fastener and the wiring including the exact colour code was the same.
If its the refigeration , its such a tiny unit and competent refrigeration repair shop can do it.
It took me a little while to find my part but it was actually in stock at Sears.
In my opinion , I would have a good look at your unit and fix it your self.
- Been thanked: 491 times
Don't buy a new unless yours is just plain ugly.
If you do decide to buy new, shop excessively - there are deals to be had out there!
jeffceo
uaesi
- Vessel Info: 2004 466 Carver
Kirt
- Vessel Info: 2000 Carver Aft Cabin 356 Motor Yacht
Re: replacing a stand-up refrigerator
- cpoint
- Has thanked: 208 times
- Been thanked: 32 times
Also should the refrigerator work if I am on shore power and have the 2 receptacles ON for shore power side while refrigerator is OFF on DC panel side? Last week I was playing with combinations of DC power ON , refrigerator ON and also both OFF bit receptacles ON for AC side of panel, maybe I tripped some breaker at that time...
I surely do not want to even consider replacing a refrigerator now...
- mjk1040
- Been thanked: 248 times
cpoint wrote:Source of the post.......should the refrigerator work if I am on shore power and have the 2 receptacles ON for shore power side while refrigerator is OFF on DC panel side?......
You don't mention whether you had the refrigerator AC breaker ON. If it works on AC but not DC, you could have a DC supply issue or a board problem in the refrigerator.
The circuitry in an AC/DC refrigerator is designed such that when both AC and DC breakers are on, and you're plugged into shore power, the refrigerator will operate off the AC supply. If the AC power shuts down, the refrigerator switches automatically to the DC source. So if the DC side is shut off, the AC side will still power up your refrigerator as long as there is power and the breaker is ON.
If it's not working on AC either, do you have a separate AC breaker labeled/dedicated to the refrigerator? Some boat wiring is such that the refrigerator supply is combined with other outlets, so it would get its power from let's say a port receptacle breaker for example. In other words, it's not a dedicated refrigerator circuit. If this is the case, you could have a tripped GFI outlet typically in one of the heads, or a faulty outlet where the refrigerator outlet is wired to, or a poor connection.
Before you go out shopping for another one, check to ensure you're actually getting power at the refrigerator outlet itself, and are getting 12 volts supply measured at the refrigerator.
Users browsing this forum: stach454 and 12 guests
