oil pressure dropped, now wont start
- cpoint
- Has thanked: 208 times
- Been thanked: 32 times
Back with another never ending problem. Took it out Saturday. All was sounding great. All indicators were good (engine temp, oil pressure) on both engines. After about, maybe 30 minutes, I noticed starboard side, oil pressure dropped from 1/2 indicator to 1/4 indicator. Everything still sounded fine and functioned fine, so I returned back to dock to not do any damage in case there was some serious problem. I was not sure if it was just the dash board display. But got side tracked and did not restart the engine after docking to see if it would pop back to normal. Anyway, then I proceeded to change oil on both engines, as it was on add mark. yes I had neglected changing timely matter and checking. after changing oil and filter (correct oil and filter as recommended by mercruiser ), I started the starboard engine, at least attempted. nothing happened. did not turn over. when i listened i the engine room, there was a wining, ticking noise. after a friend of mine checked around, notice sound and vibration was coming from, i believe fuel pump. see picture attached. I had the fuel pump replaced 8/2016. did not put that much time between than and now, so not excessive used, I suspected oil pump, or oil pressure switch or something. I will talk to my mechanic tomorrow, but any ideas from anyone here, what it may be. by the way port engine, oil change was success, all worked, and that's my usual troubled engine. thanks in advance for your input. also this is a mercruiser 7.4 mpi. 200 model.
- 390Express
- Captain
- Has thanked: 141 times
- Been thanked: 15 times
Re: oil pressure dropped, now wont start
Unless you had a sudden spike in temperature, or a mechanical failure somewhere, you shouldn't see a sudden change in your oil pressure.
- cpoint
- cpoint
km1125 wrote:Source of the post Did you check to make sure it's in neutral?
Yes, I am not much of a mechanic, but that I know
. Minor things I can do mechanically. But when its over my head, or if too difficult of an area, I let go and get a mechanic.. Also as mentioned, there is no sign of turning over in the helm. But if you are in engine room, you hear kinda wining and clicking noise from that unit that I placed a picture of on top of the posting. Looks like that's where fuel pump is I believe.- km1125
If it won't even crank over, that's a simpler system to troubleshoot. You were in there messing with oil and filters, could you have knocked a wire or connector loose on the neutral-safety switch or solenoid?
If it won't crank, theres's few things to consider;
battery-cables-breaker-ignition switch-neutral safety sw-solenoid-starter
- cpoint
- Has thanked: 603 times
Hard to focus right in , but your pic appears to be the fuel pump.
- cpoint
The fuel pump SHOULD make a sound when you turn on the key, so it primes the system. If it make some unusual sounds, then it may have an issue, but that shouldn't stop the engine from being able to crank. It will only run for a few seconds without oil pressure, so if it started and then dies, then I would suspect oil pressure or a problem with the fuel not being able to pressurize.
You can have no oil pressure, no fuel pressure and no fuel but the engine should still crank. If it doesn't, fix the crank problem before you look at anything else.
