oil pressure dropped, now wont start
- cpoint
- Has thanked: 208 times
- Been thanked: 32 times
Re: oil pressure dropped, now wont start
1) 30 minute into our day out on water oil pressure dropped from 1/2 marker to 1/4 marker.
2) I did not notice it was a quick drop or slowly dropped, but it was maybe between 5 minutes and 15 minutes when I noticed the drop.
3) Returned to dock, did an oil change on both engines. They were both low (one on ADD mark other little over)
4) started port engine for a minute or two, recheck oil level, added final quart, all is well
5) Try to start starboard, nothing. double check the gear for neutral and try 2-3 times, nothing happened.
6) Friend went to engine room, I tried from helm, he said there was wining noise and clicking.
7) after couple times, he located sound coming from the pictured item (fuel pump), also held it and felt the vibration in the box when I tried to start.
8) Posted here to get some ideas and checked over google. Oil pressure switch/sender seemed like the issue fit my story.
By crank, I get the initial beeping when key is turned, but here nothing upstairs. So I am assuming its not cranking. But there is a noise coming from the fuel pump, so it is trying to do something maybe. Never listened before, so not sure what is unusual noise? So that's where I am. I put a call to my mechanic, but have not heard back yet.
Dismiss the sounds coming from the fuel box at least until you can get the engine to crank. They have nothing to do with it, OTHER than the prove that you're actually getting power from the key back down to the engine, which is a good thing.
Sounds like you had SOME oil pressure the whole way, so I wouldn't be too worried yet. I would want to know why it dropped, but that could just be a gauge, connection or sender issue. I assume the gauge goes to zero when the ignition is off and the engine isn't running (so it's not a stuck gauge)? I would dismiss that too until I could get the engine to crank.
- cpoint
BTW, the box is a cool fuel unit. It contains the fuel pump, raw water cooler, and the fuel regulator. As mentioned, the wining noise there is normal, within reason.
I agree with KM, don't worry about the oil pressure yet, it could be something simple. Deal with that after you get the engine running. AND, WHY did you let the oil level drop that low?? Check it more often!
Keep us posted please.
- cpoint
Will not happen again. I will check on volt gauge when I return back to it.Tom, switch is always on BOTH option. Not sure how to spin manually? But it was running. Batteries are new (all 3 of them). Also port side starts fine, so don't think its batteries. but starter or its connections can be checked.
The more I get into it now, its getting into a longer list
I already called the mechanic if they beat me to it, I guess it will cost me but they will take care of it. If I get there before them I will try all suggestions here as best I can and will keep you guys posted. Thanks for all the info.- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Thanks for keeping us updated.
- cpoint
- Has thanked: 603 times
- cpoint
