oil pressure dropped, now wont start
- mjk1040
- Been thanked: 248 times
Re: oil pressure dropped, now wont start
- cpoint
- Has thanked: 208 times
- Been thanked: 32 times
mjk1040 wrote:Source of the post Why was the oil low?
With all the ongoing problems, not getting good ride time on it, failed to check, assuming I was not running the engines so much. But as it turns out, I was told if you are running at 2000rpm or over, these engines can consume good deal oil. It was just my stupidity. It is on my list of items to check weekly now.
Stuff happens. A quart on 7.4 that holds 8 quarts is not going do in your engine. Check the level regularly, but don't beat yourself up if the level is a bit below the full mark.
tomschauer wrote:Source of the post ....Check the level regularly, but don't beat yourself up if the level is a bit below the full mark.
+1
Better a little low than overfilled.
- cpoint
so I ordered another solenoid for port side. Mechanic replaced the starboard side, so I need to figure out how to replace port side, not sure where it is exactly or if in a easy spot. anyone have any pointers on replacing it please be my gust in explaining
- Has thanked: 603 times
