Main breaker type
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 210 times
Main breaker type
Postby pepmyster » June 18th, 2018, 10:11 am
Hi everyone, need to know what type and brand of main shore 1 breaker is being used. We need to replace it as the it is finished. It is and has 3 breakers rivited together. 2004 360 Sports Sedan. Thanks in advance, Andrew
Re: Main breaker type
Postby bud37 » June 18th, 2018, 11:33 am
You can checkout the parts listing for your boat if available at Carver Yachts....but if you remove the bad one there will be a info right on it or should be, then you can replace in kind, common stuff.
pepmyster
8.1 Volvo Penta
Fresh water boating
Postby pepmyster » June 18th, 2018, 12:04 pm
I’ll check, couldn’t see any parts numbers on the breakers.
Postby km1125 » June 18th, 2018, 5:40 pm
Since you have a newer boat, you can probably email Carver and they could give you the manufacturer and part number.
That main likely has a built-in reverse polarity sensing circuit, so make sure you replace with similar.
pepmyster
8.1 Volvo Penta
Fresh water boating
Postby pepmyster » June 19th, 2018, 5:55 am
Emailed Carver, Chatted with Pat Johnson, We are ordering the original today. Very fast response and very resonable price for the breaker. Great customer service!!!!!!!
Postby Viper » June 19th, 2018, 7:07 am
It's probably a 3 pole Carling breaker
pepmyster
8.1 Volvo Penta
Fresh water boating
Postby pepmyster » July 4th, 2018, 6:13 am
All installed, NOW it's perfect! Thanks to the Carver parts dept for their fast service!!!!!!!
Postby Midnightsun » July 4th, 2018, 7:59 am
Just for the record and information for others what type/brand was it?
pepmyster
8.1 Volvo Penta
Fresh water boating
Postby pepmyster » July 4th, 2018, 5:54 pm
PART- 8900333 BREAKER:30A 3 POLE MAIN
Carling Tech
Return to “Electrical”
