Ice maker 355 how to remove
- tgmkwill
- Vessel Info: 1997 355 Carver Aft
- Has thanked: 1 time
- Been thanked: 3 times
Mine also had the small sink. Ice maker all off a sudden will not turn on. No fan or compressor. nothing.
Going to make sure it is getting power first. Is there an outlet inside the wet bar enclosure the ice maker is in? I have checked all breakers and GFI outlets. Any ideas how the power is wired to this area?
The outlet right next to the wet bar area does work, although you sometimes have to juggle the cord. Thanks for any input.
Re: Ice maker 355 how to remove
The unit should be fastened with screws on the flange/frame around the perimeter. There should be an outlet in the compartment behind the unit. There's a breaker at the panel and a rocker switch on the unit itself. Was it working for you then suddenly stop, or was this the first time turning it on this season? Pull the cover off the timer and turn the gear manually. Ensure the off lever on the right is down. When you turn the gear, the inlet water valve should activate and if you continue to turn it, the compressor should come on. If these happen, you may have a bad timer. If nothing happens when you turn the gear and you've confirmed there is power to the unit, it could be a number of things but the above is a good/easy start.
- Been thanked: 654 times
https://express.google.com/product/6507 ... XgodDiMHJw
- tgmkwill
- Wayne162
- Captain
"Change In Latitude"
Home port - Charleston, South Carolina - Has thanked: 16 times
- Been thanked: 32 times
- Contact:
- tgmkwill
- daveS
- Vessel Info: ☀️Sanity Sol☀️
1999 350 Mariner - Location: Penetanguishene, Ontario
- Has thanked: 24 times
- Been thanked: 8 times
Users browsing this forum: Google [Bot], Rocketman and 39 guests
