Looking for part on exhaust system
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 413 times
Postby Cooler » June 19th, 2018, 10:49 am
Hello All! I have a 1995 Crusader 350XL engine. The first fiberglas exhaust connector, with the built in back flow flapper, developed a crack and is leaking. It's about 5" long, and 3 3/4" wide. Anyone know where I can get the replacement part? The boat is a 330 Mariner. Thanks.
Cooler By The Lake
Re: Looking for part on exhaust system
Postby bud37 » June 19th, 2018, 1:28 pm
Perhaps a Centek part....crusader/pleasurecraft marine parts.....have a fibreglass guy look at it, may be repairable.
SanJuanDreamer
Vessel Info: Still Searching
Been thanked: 21 times
Postby SanJuanDreamer » June 19th, 2018, 4:38 pm
As Bud37 mentioned....
On my Mariner, I have fiberglass mufflers, they have the back flow flappers.
They were leaking at the flapper axis.
I thought I would replace them but found they are ~$700ea...so...
I asked around and found out since they are fiberglass it can be repaired.
Cooler
Postby Cooler » June 20th, 2018, 10:07 am
Thx for the replies. The crack is not in the muffler, but the first connector immediately aft of the exhaust manifold. Fiberglas guy said he may be able to repair, but there is an overlap that concerns him. In the meantime, I found a stainless steel connector that may work, but it is an inch shorter. It is sold by Marysville Marine products. I will let you all know if that works for future issues. Thx again. Visit beautiful Door County in NE Wisconsin!
Cooler By The Lake
Cooler
Postby Cooler » July 6th, 2018, 8:38 am
Hello again. Follow up to the exhaust connector issue. The SS version available at MarysVille worked great. It is an inch shorter than the OM part, but there is enough length to get good connection to the exhaust hose. Part is $70. Happy cruising!
Cooler By The Lake
390Express
Has thanked: 141 times
Been thanked: 15 times
Postby 390Express » July 9th, 2018, 11:59 am
Cooler wrote:Source of the post aust hose. Part is $70. Happy cruising!
What did you end up doing with the fiberglass piece?
Cooler
Postby Cooler » July 11th, 2018, 9:03 am
I still have it. I may get it reglassed and use as a backup. Why do you ask?
Cooler By The Lake
