Transmission Fluid Pump
Re: Transmission Fluid Pump
Here is the "Liberty" trans (might be the same as a 5000):
- crquisto
- Vessel Info: 2000 Carver 406 Aft Cabin, twin 7.4 gas Mercruisers - Flyboy II
- Has thanked: 2 times
- Been thanked: 3 times
Today I ran the boat briefly to check out performance after replacing plugs, wires, rotors, distributor caps, oil, fuel and gas filters. I ran in forward at WOT for about 5 minutes with no horns or other anomalies. On return, with engines idling in neutral, I checked some temps. The port tranny was about 20 deg. F warmer than the starboard and both were cooling down pretty quickly. Also, I found a 10 deg. F drop on both sides across the tranny coolers. I have a mechanic coming to read codes on Friday and I hope this is just a bad sensor as Viper suggested.
That still doesn’t explain why I can’t get an accurate fluid level reading on the port side by following the book. When the book says to stop the engine and “quickly” check the fluid level, what is “quickly”? I can get there within about 20 seconds on my bum knee when I do it myself. Do I need to get some help so I can read it quicker?
- Keith S
- Vessel Info: 2005 38 Super Sport
- Been thanked: 21 times
