Courtesy light 1997 355
- tgmkwill
- Vessel Info: 1997 355 Carver Aft
- Has thanked: 1 time
- Been thanked: 3 times
Tugging fairly hard on the fixture it only moves it out about 1 cm, as soon as I let go it snaps back into the hole.
Before I use the "just grip it and rip" technique, just seeing if I am missing an easy access to the backside of where the light is attached. I want to replace the light fixture, so it does not matter if it breaks. Just wondering if any other wires are is behind it before I do this. Don't won't to make a bigger problem.
I can't believe I had to type 3 paragraphs about a small little light. That's a boat for you .
Thanks.
- Has thanked: 603 times
Re: Courtesy light 1997 355
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
- tgmkwill
I was also thinking of taking the bolster panel off inside the salon on the starboard side where the light switches are as you stand at the base of the steps. A lot of screws and trim to remove, and still not sure if i would have access to it.
If exposed to weather, the light could be caulked in place but probably does have some clips to hold it in place even if not caulked. You can use something like dental floss to cut away most of the caulk to help loosen it.
Are there any other similar lights on the boat that you might be able to explore easier to understand how they mount?
- tgmkwill
- tgmkwill
[image][/image]
- mjk1040
- Been thanked: 248 times
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
..Aaron
SeaDragon
- tgmkwill
