Steering not working on the 3207
jwrape
Topic author - Deck Hand
- Vessel Info: 79' Carver 28 Mariner Twin Pleasurecraft 302's (For Sale $12,300)
85' Carver 3207 Aft with Mercury 5.7L - Been thanked: 1 time
Re: Steering not working on the 3207
- Been thanked: 491 times
jwrape
waybomb wrote:You should get a bicycle pump and pump that up to about 30 psi. You may have a small leak someplace. Note the indicated pressure after recharging and also make a mark on the reservoir for fluid height. Check every once in a while. If either is dropping, you must find the leak or one day you may find no steerage!
Ok Ill pump it up and see what it does. i don't want to drive home with just the motors
gyani
- Vessel Info: 1984 carver 3207 aft cabin
and tracking the lines to find the pump(witch was under the mattress in the sb bed) found no fluid and no pressior.
filled it up with fluid and used a bicycle pump to get it to 30psi and guess what... worksbeautiful!!! you guys are great:)
Have to wonder why the reservoir was empty - it takes some doing to empty it manually.
jwrape
nolacarver
- Vessel Info: 1979 33' carver
New Orleans, LA
Watch the gauge for a while - if it drops, you have a leak. If not, go up to the bridge and turn the wheel 50-60 360 degree turns in one direction, then 50-60 turns in the other.
You'll then want to recheck you fluid level, since it has most likely dropped as you moved fluid from the reservoir into the upper bridge lines and pump. If you want to add more fluid, remember, discharge the air first or you'll see what a steering fluid volcano looks like! Once you fill it about halfway, pump it up with air again.
Then check it every once in a while. If it drops, you'll have to find the leak and fix it.
jwrape
waybomb wrote:To fill (never full, maybe half way), discharge the air pressure. This is done with the tire-valve looking thing; that's what it is, a Schraeder-type valve. Simply depress the center pin until all the air is out, plus a little longer. Then you can either unscrew the gauge with a wrench at the fitting, unscrew the Schraeder fitting, or rig up something to add liquid through the Schraeder valve. Fill the fluid to about halfway, then get a bicycle pump or a portable small air compressor, and pump the gauge up to about 30 psi.
One thing that happened to me is when I turn my wheel to the starboard it has a stop, when I turn to port it keeps turning. When I was spinning it up on the bridge I notice fluid coming out, at the same time my wife yells "It's leaking" and it leaked down stairs in the helm as well. I think it has a over flow at each wheel. Be aware cause the original RED fluid stained my carpet in my salon
Users browsing this forum: Carverlvr2 and 24 guests
