Hot Manifolds
- 390Express
- Captain
- Has thanked: 141 times
- Been thanked: 15 times
Hot Manifolds
System is a full closed system, never in any salt water. No cracks in the manifolds.
**** Unrelated issue for extra credit... In the fiberglass exhaust T fitting or joint on the port motor, it sounds like there's debris in there. I really thought it was a spark knock (intermittent, sharp banging noise), but when I crawled down into the engine bay, it sounds like its coming from that exhaust fitting/joint/elbow. I can feel it with my hand and hear it much louder at the exh. fitting. Any idea what it could be, or how best to get it out, other than the obvious?
- Has thanked: 603 times
Re: Hot Manifolds
- mjk1040
- Been thanked: 248 times
Re: Hot Manifolds
- 390Express
- Captain
Re: Hot Manifolds
mjk1040 wrote:Source of the post Try running some RydLyme thru your engines to descale them. A 50/50 mixture for 4-6 hours in the engines will open any clogged scaled up areas and improve your fresh water cooling. There is a check/clapper valve in there that has a rubber edge on it and over time that rubber rots off and you have just metal and you here it flapping now.
It's on the closed coolant side. I can just mix Rydlyme with the antifreeze? Or should I disconnect the manifold and try treating just the manifold?
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: Hot Manifolds
- 390Express
- Captain
Re: Hot Manifolds
This is my first experience with a closed cooling system, and an expansion tank. Unlike a car, which primarily runs off of gravity (if you have low coolant in a car, and fill through the expansion tank, the coolant will go into the radiator), It seems that the marine counter-part runs off of pressure and a created siphon, so if you don't create the siphon buy forcing fluid into the tank, it won't run back out of the tank. That's my theory anyhow... Seems to be running fine now.
Idle on that motor is still very erratic, but one step at a time. It's getting there.
- RobGunn
- Vessel Info: 1990 Carver 3607 Aft Cabin
"FINALLY" - Location: St. Joe MI
- Been thanked: 23 times
Re: Hot Manifolds
Re: Hot Manifolds
390Express wrote:Source of the post Well... here was the issue... The block had little to no coolant in it. The reservoir was full, (I added a small amount at the beginning of the year, leading me to believe that the motor also full. It wasn't. Thankfully I only let it run for 10-15 minutes before realizing that the manifolds were unusually hot. I was trying to trace the issue by squeezing the hoses (to see which hoses didn't have pressure), and traced it back to the therm housing. Opened the term housing, and nothing... dumped in a gallon of antifreeze and half gallon of distilled water, and now everything is fine.
Seems you may have to pressure test that side......I would want to know where all that coolant went, maybe contributing to the miss. When the coolant contracts on cooling it will pull the fluid from that tank, so long as there is coolant in there and no leaks in the system.
- RobGunn
Re: Hot Manifolds
- 390Express
- Captain
Re: Hot Manifolds
