5.7 MPI Crusader Cruise and WOT Expected RPM?
- steveoh
Thanks.
Steve
- Has thanked: 603 times
Re: 5.7 MPI Crusader Cruise and WOT Expected RPM?
If this is the same boat you have been asking about, sounds very much like it may not have been kept up lately....you got mould, leaks,bad smells, now the rpm thing.....are you working with your own broker or surveyor to help protect you here ? Good luck man and be careful.
- steveoh
bud37 wrote:Source of the post Heh Steve.......there are any number of things, wrong props to bad fuel to tune ups, .....on salt though first guess is bottom cleaning .
Thanks for the reply. I didn't realize bottom cleaning could make that much of a difference. Given that it's not a new boat (by a long shot), I would assume the owner would have worked out what props to run. If we get serious enough about this boat to make an offer, it would be contingent on a survey and probably mechanical inspection. We're not working with a broker at this point because it seems pretty easy to find boats that are listed for sale on the web.
- mjk1040
- Been thanked: 248 times
- steveoh
mjk1040 wrote:Source of the post RPM's at WOT should be around 4500.
Wow. Thanks for the reply. Are there certain reference sources that you use for this kind of info on Carver boats on the web?
- Been thanked: 654 times
#4 refers to obtaining the manual.
https://www.carveryachts.com/support/faq/
also heres a link to a parts manual on that boat i found
https://carveryachts.blob.core.windows. ... ual_99.pdf
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
A good running boat from even getting up on plane.
Buying a boat involves a survey which should include a haul out to determine the condition of the bottom. If dirty, it needs to be cleaned. With a clean bottom, if the boat can’t get up to speed and specified RPM’s, now you know you have other issues...not a dirty bottom.
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Users browsing this forum: Google Adsense [Bot] and 15 guests
