Velvet Transmission sensor bypass
- flo2
- Vessel Info: 1987 Carver 3207
- Has thanked: 1 time
The sensor has 2 pins, a black wire coming from the transmission goes to one pin and another beige wire goes to the other pin. One of the pins broke on the sensor and now the buzzer is on full time.
I will replace this sensor but in the mean time I want to bypass the sensor to shut the buzzer off. Not sure if I should just connect both wires together or connect them both to ground.
Mike
- flo2
Re: Velvet Transmission sensor bypass
If I fallow the beige wire, it goes from this switch to the port side of the engine (1987 Mercruiser 5.7L) I think this is the oil pressure sensor and then from there it goes to the the engine temperature sensor and then it goes to a bunch of wires wrapped together.
I noticed the engine temperature sensor has a lose part, it is like a red plastic part. On my other engine this part is fixed. However I do get a reading on the temperature gauge and I also get a normal reading on the oil pressure gauge. How can I diagnose where the problem is located? Problem is, the buzzer is on after its delay even after the engine is running.
- flo2
Thanks for shedding the light on this.
Mike
