Carver 356 RPM issues
cpoint
Has thanked: 208 times
Been thanked: 32 times
Re: Carver 356 RPM issues
Postby cpoint » August 21st, 2018, 12:57 pm
km, not sure. how do I check Smartcraft capable? I did not see any reference on any documentation, etc.
Postby g36 » August 21st, 2018, 2:58 pm
Smartcraft is a mercruiser engines product.
Postby bud37 » August 21st, 2018, 3:20 pm
I am willing to hazard a guess here and say his engine controllers are Delphi MEFI 3, no bus to helm. Merc didn't go to their own 555 ecu till maybe around 02/03.
Postby km1125 » August 21st, 2018, 4:38 pm
I know it's in the very early 2000's, but not sure on the specific year they made them capable. I thought all their product line was capable after 2002, but some were before that.
In any case, tachs themselves are pretty inexpensive, so finding ones that look good (or that match what you want to upgrade the other to) might be the hardest part.
Postby km1125 » August 21st, 2018, 5:03 pm
g36 wrote:Source of the post Smartcraft is a mercruiser engines product.
I thought he did have Mercruisers in the boat?
However, checking the Smartcraft sites, it seems like his 2000 is just a tad too old to have it:
"The SmartCraft line of products are applicable to all Mercury/Mariner OptiMax outboard engines starting with Model 2000, and all MerCruiser 8.1 liter engines for Model Year 2001."
Postby tomschauer » August 21st, 2018, 8:21 pm
I had a 2005 Crownline with merc 5.7 magnums, and the ecms were not smart craft capable. I think it was an option for most engines until 20XX?
cpoint
Postby cpoint » August 22nd, 2018, 3:54 pm
Yeah not sure, I am at a loss on this one. Here is a picture of port engine for what it's worth.
Postby tomschauer » August 22nd, 2018, 7:42 pm
They aren't smartcraft engines.
Close to the same as mine, but mine are blue water horizons (freshwater cooled). I would replace the tachs until you get the engines running correctly.
I would definitely verify the fuel pressure is correct. These have a mercury "cool fuel" set up with the fuel pump and regulator in a box under the engine that is water cooled. The regulators fail more often than the pumps. They sometimes fail to high pressure, making you engines run very rich (smell like gas) this will also damage the injectors.
Postby tomschauer » August 22nd, 2018, 7:46 pm
Hey, I almost forgot...
There is a very fine fuel filter in the cool fuel box. It could be that simple!!!!
cpoint
Postby cpoint » August 23rd, 2018, 12:47 am
tomschauer wrote:Source of the post Hey, I almost forgot...
tom, do you mean this tiny filter? if so that did have some stuff in it. he thought he would clean and hope also, but did not help.
