Maxwell RC Windlass ID and Assistance
- 390Express
- Captain
- Has thanked: 141 times
- Been thanked: 15 times
I tried bypassing the solenoids to get the anchor down, so I can use the anchor without the windlass. I don't have the manual recovery handle (I need one and need to figure out where to buy one). I was told that it's a large torx bit, but a big negative there. After spending $60 on a T55-T100 set, I realized that none will fit. It's some proprietary handle size. It's approximately 1" point to point (it measures around .950 give or take .020). I ran a jumper from the power to one side of the motor and got it to move a small amount, but the issue was... if there's two choices, you go the wrong way first time, 100% of the time... That's what I did. Ran the winch a bit tighter, but only about an 1/8". It hasn't moved in 2 years, and it had a small amount of slack, I doubt I hurt anything.
However, after that, the motor wouldn't do anything, in either direction. Checked the breaker, etc., all the obvious stuff.
My question is two fold:
1) if I get new solenoids will these work? (former product code is 19045 on the box, to the extent that it helps)
https://www.hodgesmarine.com/Maxwell-Re ... iramsegdoh
Or is this the correct product?
http://www.satpro.tv/Maxwell-Dual-Direc ... 4AQAvD_BwE
and;
2) can a quality starter/electronic motor rebuilding place rebuild the motor for the windlass? Pics to follow, but they probably won't be here until tomorrow. I have a ton of work to do tonight. It's a white box mounted on the deck with "Maxwell" across it.
- 390Express
- Captain
Re: Maxwell RC Windlass ID and Assistance
Tomion
- Vessel Info: Carver 530
- Has thanked: 1 time
- Been thanked: 2 times
The main problem I had was without using the emergency handle to tighten down the clutch it would never pull up the 200 ft of anchor chain. You need to get that handle.
Users browsing this forum: Google Adsense [Bot] and 43 guests
