370 Voyager 1993 Propellers
Topic author Great Britain
Tim Sperryn
Vessel Info: Carver 370 Voyager 1992/ 1993 model
Postby Tim Sperryn » September 14th, 2018, 7:11 am
Hi
I'm seeking prop specs for the above boat with Cummins 300's?
ps: great to be part of CYO!
Re: 370 Voyager 1993 Propellers
Postby bud37 » September 14th, 2018, 8:40 am
Welcome to the forum.....is the boat new to you ?.....sometimes original prop specs from the factory sea trials could be misleading, especially for older boats that have thousands of pounds more stuff on board.
My guess , e mail Carver with your hull number and engine numbers and they may have the original specs for you.Also maybe someone here with the same combo can help......good luck man...
Postby Viper » September 14th, 2018, 10:13 am
Welcome aboard. Hopefully a nother member with the vessel will chime in.
Been thanked: 491 times
Postby waybomb » September 14th, 2018, 11:56 am
Welcome aboard!
Been thanked: 470 times
Postby RGrew176 » September 15th, 2018, 12:10 am
Welcome aboard. Good luck in your propeller search. Good news is someone here will have an answer to your question.
Tim Sperryn
Postby Tim Sperryn » April 7th, 2021, 10:12 am
Thanks all, I’m currently unable to contact Carver as I suspect the UK on it’s way to medieval times...!
Postby Viper » April 7th, 2021, 3:54 pm
Tim, try contacting Pat Johnson via email. He should be able to help. Include your hull number in the email:
pjohnson@marquisyachts.com
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 413 times
Postby Cooler » April 11th, 2021, 10:49 am
Tim - see my comments under Model Discussion category. 8-) er
Cooler By The Lake
Tim Sperryn
Postby Tim Sperryn » April 12th, 2021, 9:14 am
Many thanks for the contact!
Tim
Users browsing this forum: Google [Bot] and 48 guests
