350 Mariner Fresh water leak
- 650Guy
- Captain
- Been thanked: 40 times
Symptoms
* water accumulates in the fwd bilge whenever we are at the boat and water pressure is applied.
* No additional water accumulates during the week when we are away.
Areas checked
* all connections along fresh water holding tank are dry
* connection feeding vacu-flush toilet is dry
* Lines leading to the fwd part of the V- are dry.
* lav sink lines are dry
* Shower lines are dry
To me this only leaves the line that leads up to and under the V-berth bed. I'm assuming the lines have to do a 180 in that general area to go over to the lav area, but have no clue how to access them.
Am I missing something? Anyone have any idea how to check that area?
Re: 350 Mariner Fresh water leak
A couple things to check..
Water heater relief valve
Shower sump / ac drain
- 650Guy
- Captain
I think I have checked the hot water tank and that whole area seems pretty dry, but maybe the A/C drain I have not traced that one down. Water in my bilges makes me crazy!
- 650Guy
- Captain
- Has thanked: 603 times
650Guy wrote:Source of the post They really are bow heavy...
What year is your boat ?.....I know mine a 2001 was supposed to have the AC drain go to the shower sump according to info on the electrical panel, but it goes directly out the hull side, also maybe follow the water lines that run up to the sink etc on the bridge....
Crawl into the space under the seat by the galley sink with a very bright light .....with the water pressure on, does the pump cycle as if it is losing pressure?
- amanphoto
- Has thanked: 3 times
- Been thanked: 12 times
- 650Guy
- Captain
So spent the day trying to find this. Here is what did today:
- Completely checked the hot water tank
Discovered its on its last leg, but not the source of the leak. - fresh water collecting in the bilge is cool to the touch.
Kept the A/C unit off
Added water pressure from the shore
all bays in the hull aft of the center bays under the waist water tank remained bone dry
looked down the port side of the hull behind the kitchen cabinets as far as I could, and found it to be dry
removed the access panels under the bathroom sink, found it to be dry and no sign of water off the lines
Removed the shower controls at the handle and all lines leading to it, were dry.
Shower was not run, but all caulk was replaced
As I worked, the bay started to get water in it. Over a 3 day period, water levels would grow to just about the bilge pump.
I think this leaves;
* Water lines to the ice maker and sink up top
* Water lines that lead up to the V and 180 back to the sink & Shower
So how do I get at either of those?
