Fresh Water Pump
- mjk1040
- Been thanked: 248 times
Fresh Water Pump
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: Fresh Water Pump
- mjk1040
Careful when considering going with a higher capacity pump. You must ensure that the existing wiring/circuit is rated for the extra load usually associated with a higher volume unit.
- mjk1040
- Sailor Jerry
- Vessel Info: 1996 Carver 355
- Has thanked: 2 times
- Been thanked: 8 times
- Contact:
- Has thanked: 602 times
Sailor Jerry wrote:Source of the post The fresh water pump on my 355 went out and a local marine mechanic suggested replacing it with a size larger. He said I'd get better water pressure and flow. Well, I did as he suggested, and did get better pressure. However, I continually had issues with the pump pulsing on and off when the system was not in use. It was so annoying I ended up replacing the replacement with a pump identical to the original. No problems!
Good tip for folks, thanks.......You may have had a small leak that only showed itself at the higher pressure, was fine at the lower original pressure.......
