454 XL Possible MAP sensor issue?
- 390Express
- Captain
- Has thanked: 141 times
- Been thanked: 15 times
With partially clogged filters the starboard motor would hesitate under acceleration, but always accelerated fine and give me full RPM with fresh filters. That's no longer the case. The motor now breaks up after around 2500 rpm or so, every time, fresh filters or not, still has a check engine code. Fuel pressure is good, fuel spray pattern out of the injectors looks good. I'm guessing the issue is a bad MAP sensor. What's a good way to diagnose the issue without a vacuum pump?
I was told that the motor may run better, accelerate fine, and run a little rich if I disconnect the MAP sensor. If that is true, I suppose that would be one way to diagnose the issue. Also, can the MAP sensor be cleaned? I will check the vacuum line for leaks, kinks and clogs tomorrow morning.
- mjk1040
- Been thanked: 248 times
Re: 454 XL Possible MAP sensor issue?
- Bentone23
- Vessel Info: 1996 Carver 355 Aft Cabin
454 xli TBI Crusaders - Location: San Francisco Bay
- Has thanked: 57 times
- Been thanked: 5 times
- Contact:
Bentone23@sbcglobal.net
1996 355 Aft Cabin
Central California
Boating on the Delta and SF Bay
- Has thanked: 603 times
Bentone23 wrote:Source of the post What code reader can I buy for my 1996 Carver 355 Crusader 454xl TBI engines? Where is the ALDL connector?
Check out Rinda Technologies......
- 390Express
- Captain
bud37 wrote:Source of the postBentone23 wrote:Source of the post What code reader can I buy for my 1996 Carver 355 Crusader 454xl TBI engines? Where is the ALDL connector?
Apparently michiganmotorz.com has a MEFI 1 specific computer for $495, similar to this one:
https://www.michiganmotorz.com/techmate ... -4589.html
You can buy a slightly more expensive code reader than can do everything from MEFI 1 to MEFI 4. I'm considering buying the MEFI burn software, which allows for not only the reading and clearing, but also the re-programming of modules from MEFI 1 to 4.
Do you have any experience with any of the above?
