350 Mariner Fresh water leak
- amanphoto
- Has thanked: 3 times
- Been thanked: 12 times
Re: 350 Mariner Fresh water leak
I didn’t see it mentioned. You’ve checked all your sea stained lids and sea cocks?
Have you checked your fresh water tank for a leak?
- 650Guy
- Captain
- Been thanked: 40 times
So I'm going to start with turning off the shore water, then turn on the onboard pressure tank and wait for a pump cycle. I do lean towards the fresh water system as I will drain the entire fwd bilge and shut off the Shore water. When I return the next weekend, the bilge is still empty, yet once I arrive, and turn on the water... in time, it starts to fill again. Grrrrrrrr....
- 650Guy
- Captain
So a weekend worth of work. Here is what I have:
[list=]* Water line from dock connection to main pump dry
* bay under the holding tank, and gray water tank from the toilet is dry
* drained the water from the fwd bilge - turned everything off for the night, returned next day (about 18 hours) things remain dry.
* Ac/Heat was turned on and the heat is operating as its cold here in Cleveland.
* water at the dock is turned off, water pump is turned on but about 1 hour into working.
* pump cycles about 1 time an hour. To me that does not seem completely unreasonable? does it? I mean I would anticipate SOME bleed down of the pressure by nature, wouldn't you?
So now I'm wondering, could my A/C unit be causing this? the connection at the through hull is dry, the sea cock and strainer are tight and dry? everything aft of the bulkhead by area 1 is dry as a popcorn fart...
I'm really confused!
[img][image][/image][/img]
[/list]
- Has thanked: 603 times
Is your vacuflush raw water feed or fresh ?
- 650Guy
- Captain
I am now totally convinced that the fresh water supply is the culprit.
I have narrowed down the leak to the highlighted area... its directly under the V-birth bed. I'm just at a loss on how to change the line? access under the V-birth bed is extremely limited to no access at all. [image][/image]
- 650Guy
- Captain
So here is my plan! I found the location of the leak, but its 1 of 2 lines, hot/cold. I'm leaning towards cold as I have taken the advise of a previous post and as the water accumulates in the bay, it seems to be cold, not warm/hot. To narrow it down more, I have purchased a SharkBite cap, and will terminate the water at the split from the vacu-flush toilet before it heads to the Abis of under the V-birth. If I cap the cold and it continues to fill, well then it is probably the hot... if I cap the hot and it continues to fill... ANYONE WANT TO BUY A 350 MARINER!?!?!?! hahaha! just kidding, I'll figure it out.
Once I narrow down which line it is, I have a coupler that I bough that fits inside the line. I will use it to connect the new line and feed from the main bay (in the galley outside the lav) through the hull and up to the faucet in the lav. I'm PRAYING they did not get fancy and add an elbow or something crazy like that in the area I have highlighted in the previous post. I'm really hoping that is just a bend in the flexible line as it is under the V-Birth and getting at that might be... no it IS an issue.
I will try and update with pictures as I go in case anyone else runs into this same issue... maybe my pain, is someone else gain!
- mjk1040
- Been thanked: 248 times
- 650Guy
- Captain
Dang I hate water issues!!!
