Off season therapy
- Has thanked: 602 times
Re: Off season therapy
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Darrenlife....what brand/model drain plug light did you have? Bright enough? Some of the brands require replacing the plug fitting. Trying to avoid that. BoatPlugLight has a 3 light model, Medusa, but it appears I need to change out the drain plug fitting. Really don't like the idea of pulling out something that is sealed, providing no issues currently. Thanks for your input.
Follow up comment on navigation equipment....all manufacturers change their models more frequently than I change underwear. Wish they would stick with their winners a little longer. Have a great day all! Packers play today!
darrenlife
- Vessel Info: 2002 Carver 410 Sport Sedan
- Been thanked: 36 times
I liked the remote to change colors and effect!
Packers shouldn’t have a problem against the Dolphins today, my Steelers won again on Thursday!
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
- Cooler
Rick - there are a number of options that attach to your trim tabs. You can run the wires through an existing hole so you do not have to cut more holes.
darrenlife
darrenlife wrote:Source of the post Sorry about the Amazon link, here is the description: Ronben Set 9LED 27W Cree Led Multi-Color RGB Boat Drain Plug Underwater Light IP68. It threads into the standard drain plug socket leaving about 1.5" depth of the light from the transom.
Found out you cannot copy paste a link into a thread if it goes to Amazon. Instead use the URL feature. And low and behold. https://www.amazon.ca/Ronben-Multi-Color-Drain-Underwater-Light/dp/B01I8XU9ZG
- mbenner
- Vessel Info: 1993 Carver 300 Aft Cabin
- Cooler
- mbenner
Return to “Boating & Cruising Lifesyle”
