Question on overheating repair or replace
Re: Question on overheating repair or replace
Algae growth, zebra mussels?
Hope you figure it out.
- Has thanked: 603 times
Nharrison5 wrote:Source of the post I neglected to mention that the oil pressure runs a little higher on the starboard engine, also
In reality an engine that is running hotter should show a slightly lower oil pressure as the oil temp would be higher. The trouble is that until you get the prelim stuff done it is really just guessing . I think I might verify the temp and oil pressure gages with an IR temp gun on the sensor and a remote oil pressure gage.....that way you will know for sure and double check your dash gages.......good luck man.
- Helmsman
- Has thanked: 73 times
- Been thanked: 42 times
tomschauer wrote:If you replace the impellers every year, something else is making you run hot. What could be restricting your flow?
I think the new impeller failed. Just won’t know that until I pull it. That is what Occam’s Razor would say.
Has she ever been in salt water and if so, for how long?
- Helmsman
Viper wrote:When you pull the impeller, check the inside pump housing, wear plate, and cam. A new impeller won't make much of a difference if this hardware is worn.
Ok. I will. Freshwater on Lake Chickamauga in Tennessee her whole life.
- Helmsman
Viper wrote:Source of the post I wouldn't worry much about the exh. manifolds if she's a fresh water vessel unless further diagnosis takes you in that direction. You could have garbage or impeller pieces from a previous failure in the HE or cooler though. Impeller pieces have to be removed manually or flushed out but try Rydlyme to descale and clean the HE and cooler before removing and sending out. Of course check all the other normal things like intake hoses, connections for leaks, strainers, seacock, etc.
Thanks! I won’t be able to get to the boat until January, but will follow that approach. Just have to pick a set of warm days!
- mjk1040
- Been thanked: 248 times
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- Cooler
