Looking at the model 396.
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 413 times
Re: Looking at the model 396.
Postby Cooler » December 20th, 2018, 8:32 pm
Waybomb - are your slip lengths true to length? The 396 is just 7" longer than the slip, if it is. In this area, the slips are a little longer than stated length because so many people go stern first. With stern in, the entire slip can not be used because of the triangle of support struts, so some marinas do not count that space.
Cigarjim - I would suggest actually measuring that slip before passing on a great boat, or moving up 5' in slip for just 7".
8-) er
Cooler By The Lake
Been thanked: 491 times
Postby waybomb » December 20th, 2018, 8:46 pm
Cooler, I own the two slips in front of my condo and a slip in the yacht club. I just know the marinas in the area very well.
Cigar, there's always pier 1000 or Brian's marina.
I believe there are a few slips for rent at SJIYC next to anchors way marina. I have a slip there but it's rented out for next season. 45 x 25. $1600/season.
I would not recommend anchors way.
Sadey
Vessel Info: Former owner of a 2003 Carver 356 with 8.1 Mercs
Agradecida
Current owner 1989 60’ Hatteras MY with 8v92 Detroit’s
Benedetto
Has thanked: 4 times
Been thanked: 29 times
Postby Sadey » December 20th, 2018, 9:03 pm
Fair market on the survey was $96,000.
Thank you for the help!
Dave & Trina
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Postby tonyiiiafl » December 22nd, 2018, 8:36 pm
My 1994 390 CPMY is 42'9" OAL
Cooler
Postby Cooler » December 24th, 2018, 2:19 pm
Yep, the 390's also had the extended bow pulpit. The 396 originally inquired about, does not. LOA on that model 396 is 40'7", taken right from the spec sheet.
Sadey, you did really well! Good for you. Can't wait to see her in Door County next season.
Cooler By The Lake
Users browsing this forum: No registered users and 40 guests
