I'm the John Snow of CYO
Johnfrmcal
Vessel Info: 1998 Trojan by Carver 440 Express
Been thanked: 3 times
Re: I'm the John Snow of CYO
Postby Johnfrmcal » February 4th, 2019, 11:31 am
Cooler wrote:Source of the post John Snow - I know where you can find 2 boats in almost pristine condition, low hours, and in that 27 - 28 ft range. Both are in Northeast WI, and have only seen fresh water. One is a Sea Ray 270 Sundancer (269 hrs), the other is a Cruisers Yachts 2870 Rogue ( 400ish hours ). Both are late 90's early 2000 model years. Beams are 9.5 and 10.0 respectively. Let me know if you want links. Carver hasn't built anything in that size since mid 90's 8-) er
Thanks for keeping an eye out! As someone else already stated, it has to be 8.5 beam or I can't tow it around this country without special permits. I've actually got my eye on one model, (well, two but they are the same boat), either a 2006 Chaparral Signature 276 or a 2006-2009 Chaparral Signature 270. They are all kinda the same in the 27' class, but the Chap has a swivel helm that joins it into the cockpit conversation which opens up the cockpit feel, and it has a convertible sunpad and a great swim step. Seemingly small differences but when you're talking 27' every little thing counts.
Postby Viper » February 4th, 2019, 1:51 pm
Johnfrmcal wrote:Source of the post
Viper wrote:Source of the post What's under the floorboards in the engine bay?
Twin Cummins 450 Diamonds, great engines!
Nice :down:
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 413 times
Postby Cooler » February 4th, 2019, 5:21 pm
John Snow - Chaparrel makes a great boat, one of my favorites. The hull is solid glass and strong as heck! If memory serves me right, they use like a 14mm rove matting between hand laid layers of fiberglass. They also use an overlap technique of joining the top deck to the hull that places them among the best! Little heavier boat compared to peers, but I'll take strength over weight any time. What power packages are on them? Hours? If one has a dual prop system, that is really helpful in maneuvering. That heavier hull will help with side to side list that most 8.5' beams produce also. Good luck!
8-) er
Cooler By The Lake
Johnfrmcal
Postby Johnfrmcal » February 8th, 2019, 1:49 pm
Thanks for keeping an eye out! As someone else pointed out, I need the beam to be 8.5 feet to be able to tow it around the country without special permits. Actually I have my eye on one particular model, the Chaparral Signature 270 or Signature 276 (same boat in 2006, I'm looking for model years 2006-2009). Most of the 27' cruisers are very, very similar. The big difference to me in this particular model is the helm that swivels to become part of the cockpit, greatly opening up the cockpit (in relative terms) as well as having a convertible sunpad and a great swim step. If anyone sees one with a big block and gennie, let me know!
