Remote Monitoring System
They have been around for a couple of years as can be seen in this review. https://sailbits.com/boat-command-initial-install/
- Has thanked: 603 times
Re: Remote Monitoring System
My interests are shore power loss, battery monitoring and high water alarm. The rest is just icing on the cake..
A good example for the shore power failure sensor build is a 120v relay plugged into an outlet with a ground wire connected to normally open contact of the relay and the other to the power failure wire of the unit. The high water is simply a connection to ground so a simple float switch connected to ground when tripped is all you need. Same goes for the alarm contacts. Any off the shelf temp sensor will also work for temp readings. This is a simple device that uses simple tech which is something I like. It has 20 wires so it can get a ground signal which is translated from the wire it received the ground from into high water to alarm or power failure. Like I said simple but effective. The hardest part is fishing the wires to the sensor locations on the boat. Stay tuned for another pimp my boat project.
The subscription can be had on a monthly basis with no activation or deactivation fees. This is my best option as 5 months is only $45 for the more than ample basic plan.
The plans vary because of the frequency of reporting but this only fills the log and has no bearing on any alarms which appear within minutes of an event no matter what the plan. I suppose for some, logging may be required but honestly I cannot see why I would want a log recorded every hour that says shore power is good, water levels in the bilge are not high and so on. Someone with a rental fleet may want to track the boats via gps with a log report every hour but otherwise I simply cannot see the value for a private boater.
Wiring instructions. https://viatrax.com/support/Manual-Advanced.pdf
Below is a chart showing the different plans, as can be seen take off 25% for a yearly plan if this option is better for you.
The unit does have GPS built in so you can see remotely where the boat is, can set up a geofence or anchor drag alarm if you so desire.
I did search around for a better deal and managed to find it on eBay for $229.
There is 1 left if this interests you https://www.ebay.com/itm/Boat-Command-B ... 2749.l2649 other wise the price is $299 on Amazon.
Actually is there not the same sort of thing that just works over wifi.
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
