Line and Net Cutter Systems
denpooch
Vessel Info: 2005 360 Mariner
Crusader 6.0 Captains Choice
Has thanked: 85 times
Been thanked: 89 times
Postby denpooch » February 9th, 2019, 12:58 pm
Hey Folks. I am wondering if any of you have one of the line and net 'cutter systems' installed on you boat which help protect your running gear from fouling.
It seems to me that they can be very advantageous, although over the past many years of boating, I have only fouled my gear twice. First a lobster pot and second time a mooring line. The difference nowadays is that I am in no hurry to have to dive below and cut the stuff off of the shaft and prop.
Any thoughts?
3dognight
Vessel Info: 2000 530 Voyager With Volvo TAMD 122P EDC 610HP
Has thanked: 15 times
Been thanked: 8 times
Re: Line and Net Cutter Systems
Postby 3dognight » February 10th, 2019, 9:20 am
I have Spurs on my 530, installed by PO who said the worked great, Boat was based out of Boston and he ran it up and down the east coast. Very many Lobster pots in New England some im guessing they did their job
Light travels faster than sound. This is why some people appear bright
until you hear them speak.........
Txcruiser
Vessel Info: 2007 560 Voyager, Volvo D12
Has thanked: 2 times
Been thanked: 2 times
Postby Txcruiser » February 12th, 2019, 6:20 pm
I had them installed for a summer season I spent in the northeast. They worked one time but the other two events required a diver to cut the entanglement. After returning to Charleston I sold them to a bloke living in Maine. For me, I wouldn't add them if I return north.
Keith S
Vessel Info: 2005 38 Super Sport
Been thanked: 21 times
Postby Keith S » February 15th, 2019, 10:50 am
Spurs work well, but they are expensive. The installation is a little difficult, you need enough clearance behind the prop and the strut must be drilled and tapped. They also need routine service, the zincs need to be replaced, nylon bearings wear and need to be replaced. They need to be sharpened occasionally. I have seen the Shaft Shark units on a trawler, but the owner had not run into any lines to say if they worked. They look impressive though.
Users browsing this forum: Google [Bot] and 14 guests
