Oil filter for Crusader 350XL?
RickieT
Vessel Info: Carver 350 Mariner 1997
Has thanked: 18 times
Been thanked: 3 times
Postby RickieT » April 22nd, 2018, 2:15 pm
Getting ready to change the oil in both engines. Anybody have their go-to oil and filter brands?????
Thanks,
Rick
Re: Oil filter for Crusader 350XL?
Postby bud37 » April 22nd, 2018, 4:30 pm
Rotella t 15w40.....wix filters.....let the games begin....... :popcorn:
Postby g36 » April 22nd, 2018, 4:45 pm
bud37 wrote:Rotella t 15w40.....wix filters.....let the games begin....... :popcorn:
+1 :drunk: I like it
RickieT
Postby RickieT » April 22nd, 2018, 6:43 pm
Anyone know what filter fits a 1997 350 mariner?
Been thanked: 248 times
Postby mjk1040 » April 22nd, 2018, 8:07 pm
RickieT; The filers will be the same as the ones for a Ford V-8, Wix 51515 I do believe. Even though a lot run Rotella 15W40, I prefer to run what is on the oil fill cap and what the manual suggest which I believe in your case will be 30W or 40W. Now you can find that in the Rotella brand at most Tractor & Farm Supply stores. From what I have seen and read stay away from Fram brand filters.
SanJuanDreamer
Vessel Info: Still Searching
Been thanked: 21 times
Postby SanJuanDreamer » April 22nd, 2018, 10:50 pm
Chevron Delco SAE30, as my 454's call for.
Like mentioned above Wix51515 and Sierra.
Postby tomschauer » April 22nd, 2018, 11:15 pm
Rickie, I believe Crusader calls for straight 30 weight oil, mercury calls for 15/40 synthetic blend. GM, the manufacturer of these engines calls for full synthetic on all roller cam motors from I believe 1992 on.
I run mobil 1 15/50. Others swear by the rotella.
Change it regularly and you should be good with any quality oil.
Same with the filter. I use mercury quicksilver filters.
KTWilliams
Vessel Info: 1994 440 Aft Cabin,
Full Circle
Postby KTWilliams » February 15th, 2019, 4:02 pm
Had that question yesterday and was advised not to use synthetic or multi grade. At repair service shop they told me to stick to 30 weight on crusaders. Where people went synthetic, it opened up too much and a lot of junk then fouled lines and ended up causing blown engines and big buck repairs.
Postby mjk1040 » February 15th, 2019, 4:20 pm
IMO synthetic's do not have the viscosity that plan old straight oils have. If the filler cap says 30W, then 30 W it is. The Rotella has zinc in it that helps the oil stick to all the metal parts so you don't get a dry start. IMO! Your local tractor supply and Wal-Marts carry Rotella.
Tireless
Volvo Penta D6 370 HP
Has thanked: 183 times
Been thanked: 187 times
Postby Tireless » February 15th, 2019, 6:20 pm
For what it's worth, everyone up our way uses the Shell Rotella, 15W40 in their gas engines. That is what I used in my Carver 356 with the 454's and I use it in my Volvo Penta Diesels now. As for the oil filters, I had Merc's, so I used their filters. I buy a 5 gallon pail on sale at Walmart for around $70 +- in Canada. I am sure you can do just as well in the US.
