question about changing old distributor for new electronic ignition
- KTWilliams
- Vessel Info: 1994 440 Aft Cabin,
Full Circle - Location: Tennessee
- Has thanked: 1 time
anyone else do this? What was your experience/results?
- ColRon
- Has thanked: 77 times
- Been thanked: 157 times
Re: question about changing old distributor for new electronic ignition
“Escape Plan”
Murray, KY
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
- mjk1040
- Been thanked: 248 times
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 88 times
Regarding the 145 vs. 160 degree thermostats - it depends on where you are running. You get less salt buildup with 145 - that's why they are the spec for some engines. The engine will be more efficient with a 160. IMHO - use 145 for use in salt water and 160 if you are running in fresh water.
See ya on the water!
Lake Norman, NC
Carver 3227 - "Splashy Lady"
There are several choices for electronic ignition conversions. Anything from a points and condenser elimination kit to a full distributor upgrade, and incorporating an ignition control module, etc. The key thing to keep in mind is that the distributor and supporting hardware be designed for a marine application to ensure you end up with a proper advance curve for your marine engine. You don't want an automotive advance curve in a boat.
- KTWilliams
In response to ColRon, yes they are Crusader 454's w 350 HP. The hell of it is they are running fine. And I hate to mess up something that works, but intuitively it just seems these will make it even better. Hope I'm correct cause it's a big investment in two full kits and I just don't want to screw this up...
- KTWilliams
Yes it is fresh water cooled. Appreciate your comments.
- ColRon
“Escape Plan”
Murray, KY
