Transom Lights
Sadey
Vessel Info: Former owner of a 2003 Carver 356 with 8.1 Mercs
Agradecida
Current owner 1989 60’ Hatteras MY with 8v92 Detroit’s
Benedetto
Has thanked: 4 times
Been thanked: 29 times
Transom Lights
Postby Sadey » February 22nd, 2019, 5:50 am
Has anybody added these to a 356? I would like to add them but curious about position. Seems like four would be required but where to put the other 2. Would it be a odd shape if two were in the center of the transom and the other two on the outer sponsons? Or would two be enough?
Thank you for the help!
Dave & Trina
Re: Transom Lights
Postby g36 » February 22nd, 2019, 8:21 am
sure youll get lots of suggestions but i didnt want to spend a crazy amount of money on underwater lights and i didnt want to have them pull a lot of current from my battery bank if i leave them on for hours.so on my 405 which your 356 is smaller brother . link below for lights .i used 2"s" and mounted them on a bracket i made for my trim tabs and 1"ds" mounted above the drain plug center of transom. i'm in fresh water and went with green to be better for night fishing and to be different from all friends who have blue. been in a year and i think they look very good and light pattern is equal all the way across the back. they are not very expensive like some lights out there and i figured i didnt loose much if they fail or dont look good but so far i would have done this all again
http://www.coastalnightlights.com/orders.html
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 413 times
Re: Transom Lights
Postby Cooler » February 22nd, 2019, 6:22 pm
Sadey - Dave. When do you think you will launch? The reason I ask is, I am installing some Xenon underwater lights next weekend. Aiming to launch very early May. I want to see how these work before I endorse them. One of the fisherman that come into the shop is very happy with their output. He fishes at night and says they spread light 12 to 14 feet. I am going to mount to Bennett trim tabs. Total kit should be around $200 & real easy install. 2 lights, one color, on/off switch, real simple. I am just going for that Cooler look of aft glow. You going to be in this neck of the woods before May?
Duplicate post in Detroit Boat Show category. 8-) er
Cooler By The Lake
Been thanked: 248 times
Re: Transom Lights
Postby mjk1040 » February 23rd, 2019, 7:12 am
Have you thought of a drain plug light or plug light cluster?
throwback2
Vessel Info: 1987 Carver 28 Voyager,twin small blocks,1991 Shamrock,350 Chevy now.
and a few other water toys
Has thanked: 8 times
Been thanked: 23 times
Re: Transom Lights
Postby throwback2 » February 23rd, 2019, 7:40 am
I had Coastal Night lights on my boat for years and last season,the housing on the double length finally warped and half of it went out.I would absolutely buy these lights again.
Re: Transom Lights
Postby km1125 » February 23rd, 2019, 3:26 pm
mjk1040 wrote:Source of the post Have you thought of a drain plug light or plug light cluster?
A friend of mine did that with his 356. He wanted to get an idea if he really liked it before he cut or drilled holes. He really like it and it worked so good he didn't ever buy anything different.
There are a few out there for the drain plug. There is one, I think 1000 lumens, that is all brass construction which is the one he bought.
Return to “Electrical”
