New Nav
tomtomterrific
Vessel Info: 1986 carver riviera 28
Has thanked: 14 times
New Nav
Postby tomtomterrific » March 26th, 2019, 7:05 am
Ahoy again,
I'm installing new Radar and MFD, replacing the old speedo and depth sounder.
Q - Would you remove the old through hulls?
How big of a DIY is it? I've done fiberglass work before but nothing as critical as a hull repair.
Cheers,
Cap't Tom
Re: New Nav
Postby km1125 » March 26th, 2019, 9:55 am
I would only remove them if you have something else to put in their place. Won't you need a transducer for depth info?
SplashyLady
Has thanked: 20 times
Been thanked: 88 times
Re: New Nav
Postby SplashyLady » March 26th, 2019, 10:18 am
Check the frequency of the new and old sounders. Maybe the old ones are compatible with the new equipment, and save yourself a lot of time and money. If it's the same manufacturer, sometimes the plugs will match. If it's different, you can often just splice the coax cable (something like a BNC connector) and the new sounder will work with the old 'ducer. Lots of 'ducers are either around 50-80KHz (deep water) or around 200KHz (shallow water), or both (dual frequency). The old transducer will work with a new unit if the frequencies are close. HOWEVER (there's always a catch!). Newer sounders using CHIRP or side-scan require specialized 'ducers and older models usually won't work with the new technology.
Good luck!
Captain John
Lake Norman, NC
Carver 3227 - "Splashy Lady"
Tireless
Volvo Penta D6 370 HP
Has thanked: 183 times
Been thanked: 187 times
Re: New Nav
Postby Tireless » March 26th, 2019, 10:33 am
Unless they are in the way of your new installation or are leaking, I would just leave them in. Lots of boats out there with old installations in their hulls. I would also consider what SplashyLady says, you never know, but there is a thing called "designed obsolescence" and you will find that the old will not mix with the new very well. That's how these tech companies make their money. I am currently looking to refit my boat with a new MFD and I am running into the same thing with the sonar and radar. Good luck...
Re: New Nav
Postby Viper » March 26th, 2019, 7:16 pm
What system are you installing?
I don't recall what the '86 Riviera had for a hull...cored, solid glass? This would help my decision on whether I would remove the old ducers. If it's a cored hull, I would definitely remove the old ducers. Cored or not, if there are any signs they have been leaking, remove them.
Sadey
Vessel Info: Former owner of a 2003 Carver 356 with 8.1 Mercs
Agradecida
Current owner 1989 60’ Hatteras MY with 8v92 Detroit’s
Benedetto
Has thanked: 4 times
Been thanked: 29 times
Re: New Nav
Postby Sadey » March 26th, 2019, 7:41 pm
Our boat had all Raymarine and we replaced with same. We had to purchase an ITC5 to use the old speed and depth ducer on the new Ray MFD. We also had a new chirp installed to take advantage of the MFDs capabilities. Overkill yes and cool factor high. If we had not used the old ducers we would have left them in place and zip tied the wires. No need to cause a problem where there isn’t one. The thought process was the hole might not be the same size for the new ducer so for minimal cost redundancy was added.
Thank you for the help!
Dave & Trina
tomtomterrific
Re: New Nav
Postby tomtomterrific » March 29th, 2019, 5:04 pm
Thanks everyone -
The old speedo and depth sounder units are mid 80's vintage and the old radar was Raytheon (pre RayMarine) probably also mid 80's vintage - no sign of leaks.
The new sounder is a transom mount. No new holes or reusing the old hole. Sounds like the consensus would be tidy up the old wiring and leave the old units in place!
Much appreciated!
Re: New Nav
Postby tomschauer » March 29th, 2019, 9:01 pm
Hey Tom, a transom mount transducer on an inboard boat is pretty useless unless you are barely moving. It will see the bubbles and such from the propwash and give you crazy readings. The transducer always needs to be forward of the props.
Re: New Nav
Postby Viper » March 29th, 2019, 10:19 pm
tomschauer wrote:Source of the post Hey Tom, a transom mount transducer on an inboard boat is pretty useless unless you are barely moving. It will see the bubbles and such from the propwash and give you crazy readings. The transducer always needs to be forward of the props.
+1
tomtomterrific
Re: New Nav
Postby tomtomterrific » April 7th, 2019, 6:02 pm
I took tomschauers advice and got a through hull transducer. The old ducer has a 2-1/2" diameter at the edges of the flange. My new unit requires a 3-1/8" hole. My plan is to cut the 3-1/8" hole from outside the hull by going straight through the existing ducer, with the hole saw outside the existing 2-1/2" flange, with the old unit inplacew ehile I do this.. (it's very difficult to access it from the bilge to remove) Appreciate your thoughts and feedback. Is this a good idea? Thanks, Tom
