Bildge Pump Float Switch
- Sadey
- Vessel Info: Former owner of a 2003 Carver 356 with 8.1 Mercs
Agradecida
Current owner 1989 60’ Hatteras MY with 8v92 Detroit’s
Benedetto - Location: Racine Wisconsin/Ft. Lauderdale
- Has thanked: 4 times
- Been thanked: 29 times
Dave & Trina
darrenlife
- Vessel Info: 2002 Carver 410 Sport Sedan
- Been thanked: 36 times
Re: Bildge Pump Float Switch
The speaker is disconnected or not functioning is my guess.
On my previous boat I made my own high water alarm with one of these which you could use if your alarm is defective. https://www.amazon.com/DIGITEN-Flash-Alarm-Indicator-Buzzer/dp/B017YL31OY/ref=pd_bxgy_img_2/145-0846989-5422949?_encoding=UTF8&pd_rd_i=B017YL31OY&pd_rd_r=902cc617-5897-11e9-9d06-a332060cea22&pd_rd_w=ng1MR&pd_rd_wg=B66un&pf_rd_p=a2006322-0bc0-4db9-a08e-d168c18ce6f0&pf_rd_r=K8DEKCPSKFDDJWRM1EZ9&psc=1&refRID=K8DEKCPSKFDDJWRM1EZ9
- Sadey
Agradecida
Dave & Trina
- Has thanked: 603 times
Sadey wrote:Source of the post The speaker is still attached and I assume functioning. Not sure where the sensor is for that. But it’s the high water floats that don’t seem to be functioning. One, I could see it being the float but both at the same time is odd. The other three normal floats test fine.
It is actually a buzzer, not a speaker, probably a piezo. Just apply 12v to it to see if it is functional and the we can continue to troubleshoot.
- Sadey
Agradecida
Dave & Trina
You should check (or not), the switch might actually be a breaker, that circuit needs to be protected somehow.
- Sadey
Agradecida
Dave & Trina
Users browsing this forum: No registered users and 37 guests
