forward cabin stain,3607 1987 model
RWS
Vessel Info: 1987 3607 aft
Has thanked: 28 times
Postby RWS » April 8th, 2019, 10:23 pm
Hope the picture will post. this is in the forward cabin of the boat we just bought, it appears to be an old water stain that I believe may have came from a one time or slow time event. It both feels and smells like an old event. What could cause a one time event like this or do I have a problem ?
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Re: forward cabin stain,3607 1987 model
Postby buster53 » April 8th, 2019, 10:53 pm
Just a guess, but I'm thinking the boat saw some heavy water and it splashed up into a gap in the hull-deck joint.
Postby tomschauer » April 9th, 2019, 12:58 am
I don't think that is a one time stain.
Look at areas above for places where water could intrude, such as deck railings etc. Bounce a bit on the decks and see if they flex. Keep in mind, water can travel quite a ways until it finds it way into the cabin.
RWS
Postby RWS » April 9th, 2019, 1:37 am
tomschauer wrote:Source of the post I don't think that is a one time stain.
Tomschauer, I plan to reset all the rail and cleat screws with 3M products. just thinking if this is a consistent problem the glue would have let lose and the covering would be falling down.
Postby km1125 » April 9th, 2019, 10:58 am
I have the same boat, but older ('83 3607). I don't have that problem, but I'd wonder what's at the most forward part of the stain. That part of the deck is still the 'flair' from the bow, do you could have something getting in at one of the forward cleats or deck pipes and following the flair down to where that liner is.
RWS
Postby RWS » April 9th, 2019, 1:53 pm
km1125 wrote:Source of the post I have the same boat, but older ('83 3607). I don't have that problem, but I'd wonder what's at the most forward part of the stain. That part of the deck is still the 'flair' from the bow, do you could have something getting in at one of the forward cleats or deck pipes and following the flair down to where that liner is.
By deck pipes, do you mean gas or water fills? the water fill cap does not screw on tight. Only a a turn and has no o-ring. Do you think water is getting in there and running forward?
Postby km1125 » April 10th, 2019, 1:51 pm
RWS wrote:Source of the post
No, I'm thinking more towards the bow. The deck pipes I'm talking about are for chains or ropes and are storage for when they're not in use. I have two on the deck right behind the bow pulpit (port and starboard) and the go into that little area forward of the V-berth.
How far forward does the stain go?
Postby Midnightsun » April 10th, 2019, 3:31 pm
Had something similar to that on another boats monkey fur. Definitely water intrusion. I used some powdered oxy clean mixed with warm water and patted it down wit paper towels, with persistence it completely disappears. In my case i also though it was a one time event until it came back again, sealed some more screws and stuff, cleaned it up and it eventually came bak once again. The irony is I finally did find the leak which was quit some distance away, a simple forgotten screw in the windshield frame which I found when I removed the sealing strip. This is not your problem but figure I should mention it. Point is it cleans up well with oxy clean.
RWS
Postby RWS » April 11th, 2019, 2:10 pm
Not too far past what the picture shows, but is also on the other side, just not as bad.
RWS
Postby RWS » April 11th, 2019, 2:12 pm
Midnightsun wrote:Source of the post Had something similar to that on another boats monkey fur. Definitely water intrusion. I used some powdered oxy clean mixed with warm water and patted it down wit paper towels, with persistence it completely disappears. In my case i also though it was a one time event until it came back again, sealed some more screws and stuff, cleaned it up and it eventually came bak once again. The irony is I finally did find the leak which was quit some distance away, a simple forgotten screw in the windshield frame which I found when I removed the sealing strip. This is not your problem but figure I should mention it. Point is it cleans up well with oxy clean.
Thank you, I will try oxy clean.
