Transforming Formica table to a teak table
- Been thanked: 491 times
Re: Transforming Formica table to a teak table
This is so when I drive a wood screw through the plug to force the plug out, I hit the plug on the center, or at least near center.
I've got a whole bunch to do like this, will show a pick of the table with the trim removed later
Once the plug is removed, the glue and broken off teak inside the while must be removed. The glue also guild up the flights off the Phillips head.
In the case of my very first one, the head Will have to be removed with a drill, and then once the trim is removed, the shank of the screw will have to be removed with a pair of pliers.
I only had to drill a few screws out.
So far on this one, the first six. Seems the guy putting this one together used way more glue. I can't get the bit to grab the screw head. At least these are brass screws.
Anyway, first long side off.
I used that block of oak to carefully pry the trim piece off of the screw shanks.
- BenTen
- Vessel Info: 1984 Carver 3697 Mariner - "We'll Sea"
- Has thanked: 20 times
- Been thanked: 32 times
Ben in SC
Three screws so far came out as they should. Brass drills easy though, and the head comes up the but once separated from the shank.
Probably will glue and attach next weekend. Wife needs help with the isenglass
