Transforming Formica table to a teak table
- Been thanked: 490 times
Re: Transforming Formica table to a teak table
Headlight
Drill bits and drill
Screwdrivers.
Blow gun
Thin grinder wheel had to make a slot for a screwdriver to get one of the screws out
Hammer
Awl
And block of wood to drive the trim off the screw shanks
I'm surprised those joints aren't doweled. The few I've taken off on the bridge on mine were, but I haven't taken any apart inside the boat.
But I need to move that table to get to the v drive, so no granite there.
- Has thanked: 603 times
Did you come across any of those ?
And it was on only one side of the table.
The rest off the heads were clear and once I removed all the plug pieces, they unscrew easily.
- BenTen
- Vessel Info: 1984 Carver 3697 Mariner - "We'll Sea"
- Has thanked: 20 times
- Been thanked: 32 times
Ben in SC
Somewhere in my photobucket's mariner folder shows what she's did the first time. When we got the boat, it had been outside for ten years unused. She made everything from scratch.
bud37 wrote:Source of the post.....boat makers back when used an odd brass wood trim screw called a Frearson head , looks like a philips but has a different bit....
I remember those but haven't seen them used on any builds after the mid '70s. That's not to say they weren't used after that time, but I've done a lot of woodwork on early Chris Crafts and Trojans and after that vintage I don't recall coming across them anymore. Probably for ease of production, it's way easier and faster to handle Philips screws. You can mount a Philips screw on a bit much faster than a Frearson. When you're talking hundreds or thousands of screws in a build, seconds add up.
It snowed for at last six hours yesterday here in SW Michigan.
Today got up to about 45f.
Hopefully next weekend.
