AC discharge thrull hull intererior acees
- tgmkwill
- Vessel Info: 1997 355 Carver Aft
- Has thanked: 1 time
- Been thanked: 3 times
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: AC discharge thrull hull intererior acees
- mjk1040
- Been thanked: 248 times
- tgmkwill
- mjk1040
Viper wrote:Source of the post Those have a tendency to break right where the flange meets the threaded tube. It's not always so apparent as the flange won't fall off due to the caulking. Take a close look from the outside and if you see a crack around the base of the flange in the hole, the unit must be replaced. This will be a red flag in a survey as it is a safety concern.
^^^^THIS
If it's cracking even just on the outside, eventually it will fail as Viper suggests. Then think about the ramifications. This is not like a sink drain that might leak a little water into the bilge. If you don't know it's cracked and that hose falls off inside the boat, then the A/C pump could be putting 400 GPH INSIDE your boat anytime the A/C is running. NOT a good situation.
- Been thanked: 491 times
Also used the new style fuel vents that don't stick way out.
Hull sides look much nicer.
- tgmkwill
