High amp inverter/charger install
darrenlife
Vessel Info: 2002 Carver 410 Sport Sedan
Been thanked: 36 times
Postby darrenlife » April 26th, 2019, 11:41 pm
I’m in the process of finishing my inverter/charger installation. My question is whether the isolator(alternator) cable can be connected to the battery when the charger can output as much as 120amps? I have two isolators that appear to be 70amps each tied in parallel.
Re: High amp inverter/charger install
Postby km1125 » April 28th, 2019, 8:12 pm
Is that one isolator from each engine?
Not sure I exactly understand your question. Are you concerned about the charger causing a problem with the engine or alternator?
darrenlife
Postby darrenlife » April 29th, 2019, 9:05 am
Yes, concerned that the high amps from the charger could do to the isolators? I realize that isolator is basically a one-way valve but will I be okay since the two 70 A isolators appear to be in parallel?
Postby km1125 » April 29th, 2019, 1:41 pm
It's not the amps that would affect the isolators, it would be the volts. I don't think you'd have any issue. I'm assuming those are diode isolators. If an isolator gets a VERY high voltage (spike) on the output side then it could damage it, but I would not expect anything like that from your charger, especially when it's connected though the batteries, as they are a very good buffer to voltage spikes.
darrenlife
Postby darrenlife » April 29th, 2019, 5:33 pm
km1125 wrote:Source of the post It's not the amps that would affect the isolators, it would be the volts. I don't think you'd have any issue. I'm assuming those are diode isolators. If an isolator gets a VERY high voltage (spike) on the output side then it could damage it, but I would not expect anything like that from your charger, especially when it's connected though the batteries, as they are a very good buffer to voltage spikes.
Great, thanks for your input, greatly appreciated!
Postby Midnightsun » April 29th, 2019, 6:32 pm
You may already know everything there is to know about these but see this just in case.
Users browsing this forum: Google Adsense [Bot] and 13 guests
