Aft state room toilet is plugged
- Sadey
- Vessel Info: Former owner of a 2003 Carver 356 with 8.1 Mercs
Agradecida
Current owner 1989 60’ Hatteras MY with 8v92 Detroit’s
Benedetto - Location: Racine Wisconsin/Ft. Lauderdale
- Has thanked: 4 times
- Been thanked: 29 times
Dave & Trina
Re: Aft state room toilet is plugged
Here is a link to show you how small that hole really is. A good design as after this "funnel" everything opens up to large 1 1/2" pipes therefor nothing can get stuck in the lines if it passes the smaller funnel hole. https://greenbayprop.com/sealand-vacufl ... b536862160
- Sadey
Agradecida
Dave & Trina
- Has thanked: 603 times
- Sadey
Agradecida
Dave & Trina
If you've confirmed the system is indeed clogged and you haven't replaced the duckbills/joker valves in several years, then remove them now and run a fish from that end toward the toilet. Hopefully you can break up whatever is in there. If that doesn't work, remove the duckbills and reconnect the lines, cycle the pump until it is in the up position, then do a pump-out while depressing the pedal on the toilet. This will often remove most clogs. Don't stick anything in the toilet to try and unclog the line.
BTW, the hole in the funnel acts somewhat like a macerator in that solids get broken up as they are forced through the small hole then are allowed to expand again under vacuum once they exit into the larger hose. This action helps to break things up and minimize clogging the duckbills and affecting their operation.
- Sadey
Agradecida
Dave & Trina
- Sadey
Agradecida
Dave & Trina
