Carvr 325 MY Transmission overheating
- Hepp325
- Vessel Info: 1996 Carver 325 Aft Cabin
Re: Carvr 325 MY Transmission overheating
- mjk1040
- Been thanked: 248 times
What caused the original one to fail? It's important to find this out. All too often, most common with engine failures, efforts aren't made to determine the root cause of the failure. This can lead to the replacement failing soon after if the cause was a result of something external to the unit. Seen this all too often with replacement engine failures that were eventually determined to be a result of external influences such as a fuel delivery issue for example that took out the original engine, not diagnosed/caught, the root cause of the engine failure not determined that may have pointed in that direction, and as a result, the same issue still exists and takes out the replacement hardware. What happened to the old unit and why?
