Mariner / Santego?
Re: Mariner / Santego?
Postby tomschauer » May 8th, 2019, 10:38 pm
Craig, most likely already has been checked, but the tilt / trim on the outdrives, along with the bellows and shift cable boots on the drives. Also noise from gimbal bearings, would mean they are on the way out. The brearings are realitivley cheap, but the labor is $$$.
celmem
Vessel Info: 3467 Santego 1989
330 hp 454 Crusaders
Been thanked: 2 times
Postby celmem » May 9th, 2019, 10:43 am
When I was helping my buddy shop, I was surprised that vision aft was limited in close quarter maneuvering.
To me that's a show stopper.
Craig_B
Has thanked: 144 times
Been thanked: 13 times
Postby Craig_B » May 12th, 2019, 6:01 pm
Did the test run today.
I think it went well. Engines fired up promptly and ran smooth.
Both engines made it up to 4500 RPM's with no noise etc.
There are a few minor issues i discovered but I am sure the seller will have those fixed plus any other issues that come up in the final survey.
The owner was not there to do the run but the owner of the marina took us out along with his salesman.
At first the boat would not do much more than 13 knots but after he fiddled with the outdrive angle and the trim tabs he got it up to about 20 knots +. He admitted he was not too familiar with the controls and handling of this particular boat.
Does this sound like an appropriate speed for this boat?
The only other item that has me a bit concerned was the port engine temp did not read at all at low speeds but once we where up on plane it matched the starboard gauge. About 140. I hope its just a gauge issue.
Also noticed some oil leaks that appeared to be from the valve covers and/or fill cap area.
Oil was clean and at the full mark.
Craig_B
Postby Craig_B » May 15th, 2019, 11:26 am
.............Bump
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 413 times
Postby Cooler » May 15th, 2019, 6:53 pm
Craig - yes, that speed sounds about right at 3200 to 3400 RPM. WOT at 4500 is normal. The thermostat could have been stuck wide open for that port side engine, and then recovered when some throttle got pushed up. As long as it did not get hotter than the other engine, should be alright. Minor evidence of oil leaks is normal for engines 30 years old. Looks like it is coming together! 8-) er
Cooler By The Lake
Craig_B
Postby Craig_B » May 16th, 2019, 8:10 am
Still waiting on the remainder of the survey. The weather here has been crappy which has apparently delayed him quite a but. :(
Says he will call me tomorrow and if all is good we will sign the paperwork the next day. :D
Thanks to all that took the time to help us out.
ColRon
“Escape Plan”
Has thanked: 77 times
Been thanked: 157 times
Postby ColRon » May 21st, 2019, 2:54 pm
Craig_B wrote:Source of the post Still waiting on the remainder of the survey. The weather here has been crappy which has apparently delayed him quite a but. :(
Have an update on the remainder of your survey? Inquiring minds would live to know! :-D
Ron
“Escape Plan”
Murray, KY
:usa:
Craig_B
Postby Craig_B » May 22nd, 2019, 1:05 pm
Just got the final report this morning.
Overall he says the boat is in above average condition for its vintage. :clap:
A few minor things need to be addressed but the seller said he will be attending to those issues.
Been thanked: 470 times
Postby RGrew176 » May 23rd, 2019, 1:24 am
Sounds good.
ColRon
“Escape Plan”
Postby ColRon » May 23rd, 2019, 9:28 am
Craig_B, sounds like we will be adding another proud Santego owner to the fold! :down:
Ron
“Escape Plan”
Murray, KY
:usa:
