454 Crusader XL Starting/Starter Issue
- 390Express
- Captain
- Has thanked: 141 times
- Been thanked: 15 times
The stbd relay triggers nice, and the solenoid does it's job, (still draws a ton of current jumping the solenoid) but it seems the main power cable or ground is weak or corroded. I'm torn between running a new ground, and/or tracing back the thick red power wire that runs to the starter. I see that the main power supply runs from the starter, across the port motor, and up the sidewall, likely to the Perko on/off switch that I can access from the cockpit. Does the Perko switch come apart for cleaning, or should it just be replaced if it's the issue?
- Has thanked: 603 times
Re: 454 Crusader XL Starting/Starter Issue
- throwback2
- Vessel Info: 1987 Carver 28 Voyager,twin small blocks,1991 Shamrock,350 Chevy now.
and a few other water toys - Has thanked: 8 times
- Been thanked: 23 times
- 390Express
- Captain
bud37 wrote:Source of the post The green wire is the boats bonding system ground.....there should be a large black cable on each engine grounding them to the batteries and to each other.. If the engine is trying to run 250 amps thru that green wire then there is your problem.
Where would the thick black wire be Bud? Any ideas?
- 390Express
- Captain
I’m going to pull all the grounds tomorrow and hit them with some sandpaper and no-ox/dielectric grease. Any additional advice?
If it does start and run disregard.
- 390Express
- Captain
tomschauer wrote:Source of the post Does the starboard motor start and run? Hopefully not the case but I believe you posted some issues with overheating etc. If so, if its hydro locked (water in the cylinders) it would exhibit the same symptoms. This could be caused by bad manifolds or risers, or simply a bad riser gasket. Pull the plugs and see if she spins and pumps water out of the cylinders. Don't keep trying to crank it, 'cause believe it or not you can bend a rod or two with the torque of the starter.
Starboard motor never had an over heating issue. Port motor used to get hot at idle, and would cool back down over 1500 rpm. There were two broken impeller lobes in the oil cooler. New impeller and flush this year, should be back to good. Port motor never really over heated, it just puked coolant twice and would go past 180 if it idled for more than 15-20 min.
Starboard motor has started a few times this year. I've also pulled the plugs and did a compression check, which checked out fine on all cylinders. I don't think it's anything mechanical. Also swapped the starter from one side to the other. Seems like it's definitely wiring at this point, but it's maddening. The main power to the starters for both motors really kind of come from the same place, same with the ground. Ground actually ties in a couple places, including with the port motor.
- mjk1040
- Been thanked: 248 times
